S60/V70 "R" Headlight Glass
Post 807565 by st etienne on 2016-11-26 07:48:57
So does anyone know if the headlamp glasses available from places like Skandix fit the "R"s. http://www.skandix.de/en/spare-parts/electrics/lights/headlights/lens-headlight-left-xenon/1019117/ I thought I'd seen a post about this but I can't seem to find it ? Any help appreciated.
Post 807568 by Harvey on 2016-11-26 08:00:51
[QUOTE=st etienne;807565]So does anyone know if the headlamp glasses available from places like Skandix fit the "R"s. http://www.skandix.de/en/spare-parts/electrics/lights/headlights/lens-headlight-left-xenon/1019117/ I thought I'd seen a post about this but I can't seem to find it ? Any help appreciated.[/QUOTE] The advert does say only for S60R / V70R at that price just get it.:smile:
Post 807573 by st etienne on 2016-11-26 09:23:25
Yeah I saw that, but I wasn't sure as when I did a search on here they results came back saying you could not buy the lense seperately ? And that you had to buy the full lamp. I also checked with my local dealer who also stated that the lense is no longer available : (
Post 807580 by Harvey on 2016-11-26 13:18:20
https://www.google.co.uk/url?sa=t&source=web&rct=j&url=http://www.vivaperformance.com/replacement-driver-side-headlamp-glass-lense-s60r-v70r/&ved=0ahUKEwi6n6b4wMbQAhUGBMAKHXl4BgkQFggmMAA&usg=AFQjCNHCpTTgo5xvu6lt8T2pBPQBsGW_WQ
Post 807595 by kevinking2020 on 2016-11-26 21:36:12
I brought headlight glass from Skandix. It fits perfect and really quick delivery. Image Image While I had the headlights apart, I also spray painted bezel black. Image haha i also tried to wrap the headlight for protection but that was a fail. I kept getting kinks in the wrap. Image
Post 807607 by Ettienne on 2016-11-27 19:00:54
[QUOTE=kevinking2020;807595]I brought headlight glass from Skandix. It fits perfect and really quick delivery. Image Image While I had the headlights apart, I also spray painted bezel black. Image haha i also tried to wrap the headlight for protection but that was a fail. I kept getting kinks in the wrap. Image[/QUOTE] Excellent, do you have a part number for it and cost? I too have the STD car xenon upgrades, I much prefer the black
Post 807611 by kevinking2020 on 2016-11-27 20:45:06
Here's part number this was for drivers side - 8678137 Altogether it cost £110.90 including delivery.
Post 807614 by LeeT5 on 2016-11-28 05:31:26
Did you only buy one glass? What about the other side? How easy/difficult was it to strip the headlight? Any tips!?
Post 807633 by kevinking2020 on 2016-11-28 18:49:37
I only brought glass for O/S as a stone hit the glass and made a hole. Water got inside and damaged ballast which i also had to replace. N/S glass was fine, only removed glass to paint bezel. Well I couldn't fit the headlight into oven, so I had to use heat gun. It did take a couple of hours, I was trying to be careful (R headlights are expensive!). I was going to do a DIY youtube video but i spent soo long heating it and didn't bother. I have just edit the video so it's only 2 mins long. This should give you an idea of removing the glass. [video=youtube_share;nAegH1WsmnE]https://youtu.be/nAegH1WsmnE[/video] When I did the headlights on my Type R, I was able to fit them in the oven, it didn't take long (less than an hour) and was alot easier to remove. (Also I brought a used pair, which was also 10x cheaper than the R headlights so wasn't too bothered if i broken them...) I was very impressed with myself, doing the Type R headlights. I was installing projectors in them. Completely gutted the headlights and installed projectors with HID's. Image Image Image Image
Post 807636 by kevinking2020 on 2016-11-28 18:58:15
Also you'll need to buy Butyl tape. http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=282259968136 Install new glass, use heat gun again. Use mini clamps so the glass stays in place.
Post 807645 by LeeT5 on 2016-11-28 21:10:43
I've already got the butyl roll. Thanks.
Post 807648 by Ettienne on 2016-11-28 21:15:15
Yours are painted black rather than STD car xenon upgrade
Post 807649 by LeeT5 on 2016-11-28 22:05:37
[QUOTE=Ettienne;807648]Yours are painted black rather than STD car xenon upgrade[/QUOTE] Who's, mine?
Post 807717 by LeeT5 on 2016-12-02 18:06:07
[QUOTE=kevinking2020;807633]I only brought glass for O/S as a stone hit the glass and made a hole. Water got inside and damaged ballast which i also had to replace. Well I couldn't fit the headlight into oven, so I had to use heat gun. It did take a couple of hours, I was trying to be careful (R headlights are expensive!). I was going to do a DIY youtube video but i spent soo long heating it and didn't bother. I have just edit the video so it's only 2 mins long. This should give you an idea of removing the glass. [video=youtube_share;nAegH1WsmnE]https://youtu.be/nAegH1WsmnE[/video] [/QUOTE] Thanks for the video. Why did you pull the ballast out? Thought you were just changing the glass?
Post 807734 by kevinking2020 on 2016-12-03 18:36:56
no worries. I also had to change the ballast. Water got inside and damaged the ballast. Also had to remove pieces of glass that got inside. Damaged Ballast [ATTACH=CONFIG]31244[/ATTACH]
Post 807873 by Versus on 2016-12-08 16:19:06
Hello guys If someone need headlamp, i have a pair of. good condition and good price. [ATTACH=CONFIG]31251[/ATTACH] [ATTACH=CONFIG]31252[/ATTACH] I am french but this headlight is for UK market.
