Top 10 upgrades/improvements
Post 808503 by martin_r_smith on 2017-01-05 21:36:56
Not sure if this list exists already but I would find it quite interesting if not. I think some boundaries need to be set though. For example my choice would be a brake upgrade obviously for ultimate performance you'd go AP's but being realistic a worthy upgrade is to 302's with decent pads. So I'll start with that but rearrange if you think yours is better 1) 302mm brake upgrade
Post 808506 by claymore on 2017-01-06 08:05:07
Strut brace
Post 808507 by ExternalError on 2017-01-06 08:46:20
General Suspension refresh alot of stuff can be uprated at a similar cost to standard parts Polybushes Uprated Dampners and springs - Koni or Bilstein New drop links is also a nice cheap upgrade
Post 808512 by MoleT-5R on 2017-01-06 10:57:26
3" throttle body and rip kit
Post 808513 by MoleT-5R on 2017-01-06 11:22:32
A japanfold, even stock this will be a great improvement over the very restrictive standard 850 item and very cheap compared to the s60r item, compliment this with a fully 3" system for even better results
Post 808514 by T5G on 2017-01-06 12:14:02
For the money, a HLM 304 map or a rica
Post 808516 by martin_r_smith on 2017-01-06 12:59:13
1) Full stage 0 2) 302mm brake upgrade 3) Strut brace 4) RIP kit 5) Remap 6) Springs and dampers 7) Cat back exhaust 8) 3" throttle body 9) Japanifold
Post 808517 by martin_r_smith on 2017-01-06 13:00:22
[QUOTE=MoleT-5R;808513]A japanfold, even stock this will be a great improvement over the very restrictive standard 850 item and very cheap compared to the s60r item, compliment this with a fully 3" system for even better results[/QUOTE] Japanifold in the top 10? Exhaust yes I agree but maybe 3" isn't necessarily needed for most people's goals?? Same as 3" throttle body, should it be in the top 10?
Post 808518 by martin_r_smith on 2017-01-06 13:02:42
What about the ipd arb's? I've not tried them personally but always hear good things about them
Post 808519 by MoleT-5R on 2017-01-06 13:17:48
[QUOTE=martin_r_smith;808517]Japanifold in the top 10? Exhaust yes I agree but maybe 3" isn't necessarily needed for most people's goals?? Same as 3" throttle body, should it be in the top 10?[/QUOTE] cheap bang for buck was my thinking as neither should cost much to do.
Post 808520 by Doingitsideways on 2017-01-06 13:33:39
Not to sound pedantic, but I'd have to go for a stage 0 I discovered a few ponies by replacing ignition components - plugs, leads, arm/cap... Gained me all of 0.1sec on the strip, but it drives so much better and you know you're making the most of any other mods.
Post 808521 by martin_r_smith on 2017-01-06 13:53:18
[QUOTE=Doingitsideways;808520]Not to sound pedantic, but I'd have to go for a stage 0 I discovered a few ponies by replacing ignition components - plugs, leads, arm/cap... Gained me all of 0.1sec on the strip, but it drives so much better and you know you're making the most of any other mods.[/QUOTE] Yeah I agree, and put it no 1 as it probably is the most important
Post 808522 by M-R-P on 2017-01-06 14:36:31
3" downpipe
Post 808523 by stephenevans99 on 2017-01-06 14:58:04
Decent tyres
Post 808524 by Jamest5r on 2017-01-06 15:11:43
Moving down under works great for me and car :)
Post 808525 by Doingitsideways on 2017-01-06 16:18:12
[QUOTE=Jamest5r;808524]Moving down under works great for me and car :)[/QUOTE] With those IATs?! :lol:
Post 808526 by Doingitsideways on 2017-01-06 16:19:21
No-one gonna suggest the good old "Frankie Valve?"
Post 808527 by M-R-P on 2017-01-06 16:25:43
[QUOTE=Doingitsideways;808526]No-one gonna suggest the good old "Frankie Valve?"[/QUOTE] One more click....
Post 808528 by S70T5Chris on 2017-01-06 16:31:33
[SIZE=5]1. Limited Slip Diff.[/SIZE]
Post 808529 by Dangerous Dave on 2017-01-06 17:07:29
Since no one has suggested it (and I've got one on mine).... MBC valve
Post 808531 by martin_r_smith on 2017-01-06 17:44:28
[QUOTE=S70T5Chris;808528][SIZE=5]1. Limited Slip Diff.[/SIZE][/QUOTE] Good call. 1) Full stage 0 2) 302mm brake upgrade 3) Strut brace 4) RIP kit 5) Remap 6) Springs and dampers 7) Cat back exhaust 8) 3" throttle body 9) Japanifold 10) LSD
Post 808532 by martin_r_smith on 2017-01-06 17:48:25
I suppose there should really be 2 lists, 1 for power mods and one for handling. And maybe it should be upgrades that are less than £500?? Might take the LSD of the list though with that figure.
Post 808537 by Doingitsideways on 2017-01-06 19:00:43
M59s have LSDs, not too many knocking about though. Another suggestion is of course putting the fat pigs on a diet. Rusty wings could therefore be classed as a performance mod :lol:
Post 808538 by S70T5Chris on 2017-01-06 19:18:05
[QUOTE=Doingitsideways;808537]M59s have LSDs, not too many knocking about though. Another suggestion is of course putting the fat pigs on a diet. Rusty wings could therefore be classed as a performance mod :lol:[/QUOTE] M59's have a viscous coupling. Not even in the same ballpark even as a Quaife, let alone a Gripper. I've had all 3. Personally, IMO an M59 with a viscous coupling is barely even noticeable. I fitted a Quaife to my old S70, probably 10 years ago, it was beyond words how amazing it was. Now on a Gripper in the 850, and it's another league compared to the Quaife, quite unbelievable how much difference it makes. 350hp fwd, plant it in a bend and the car just pulls round the bend, you have to experience it to appreciate how necessary a proper LSD is! I wouldn't waste my money on an M59, especially these days, IF you can even find one, they are all mega miles, well past their best, and nowhere near as robust as an M56. Keep saving and buy a proper diff!!
Post 808540 by Hybusamini on 2017-01-06 19:48:06
Definitely 100% a Gripper best mod u will ever do m8
Post 808544 by MoleT-5R on 2017-01-06 21:44:11
[QUOTE=Dangerous Dave;808529]Since no one has suggested it (and I've got one on mine).... MBC valve [/QUOTE] Lol...too late post 17 the Frankie valve care of Mr Sideways and I have one on mine to and yes it has a bent rod and it wasn't even wound in......lol
Post 808549 by Doingitsideways on 2017-01-06 22:01:20
[QUOTE=S70T5Chris;808538]M59's have a viscous coupling. Not even in the same ballpark even as a Quaife, let alone a Gripper. I've had all 3. Personally, IMO an M59 with a viscous coupling is barely even noticeable. I fitted a Quaife to my old S70, probably 10 years ago, it was beyond words how amazing it was. Now on a Gripper in the 850, and it's another league compared to the Quaife, quite unbelievable how much difference it makes. 350hp fwd, plant it in a bend and the car just pulls round the bend, you have to experience it to appreciate how necessary a proper LSD is! I wouldn't waste my money on an M59, especially these days, IF you can even find one, they are all mega miles, well past their best, and nowhere near as robust as an M56. Keep saving and buy a proper diff!![/QUOTE] Completely agree, Chris. No substitute for a proper diff. Was more meaning that there is a diff option to be had for relative peanuts if you can find one, and this seems to be a "Bang for buck" kind of thread. Suppose by the time you've paid someone to fit a possibly unknown gearbox though...
Post 808550 by Nealevo on 2017-01-06 22:06:32
Intercooler
Post 808552 by Dangerous Dave on 2017-01-06 22:49:34
[QUOTE=MoleT-5R;808544]Lol...too late post 17 the Frankie valve care of Mr Sideways and I have one on mine to and yes it has a bent rod and it wasn't even wound in......lol[/QUOTE] There was me thinking a Frankie Valve was a BOV, but of course thats Jamest5r's territory :D
Post 808553 by Redbrick on 2017-01-06 22:51:27
Correctly installed (by TW) Gripper! (Funny how all of us with them put it top of the list) In no particular order: VAG intermittent wiper relay mod V70 washer jets New shocks and spring (assuming still on stock 150K+ kit) tyres Carbotech XP10 with Motul RBF600 IPD rear sway bar Volvo strut brace Stage 0, including lambda sensor and MAF Full zorst Tim Williams map
Post 808554 by Redbrick on 2017-01-06 22:53:02
FFS... fat intercooler AEM Meth injection, hilarious fun
Post 808556 by martin_r_smith on 2017-01-06 23:05:29
[QUOTE=Redbrick;808553]Correctly installed (by TW) Gripper! (Funny how all of us with them put it top of the list) In no particular order: VAG intermittent wiper relay mod V70 washer jets New shocks and spring (assuming still on stock 150K+ kit) tyres Carbotech XP10 with Motul RBF600 IPD rear sway bar Volvo strut brace Stage 0, including lambda sensor and MAF Full zorst Tim Williams map[/QUOTE] Just the IPD rear bar?
Post 808557 by ExternalError on 2017-01-06 23:20:07
the front sway bar is to stiff for normal daily driver use from what ive read
Post 808559 by Red850Restate on 2017-01-07 05:23:57
Go faster stickers and certainly the obligatory "Moose sticker"
Post 808576 by jdavis on 2017-01-08 08:38:06
V70 washer jets? From a p1 of p2? Are they are straight fit?
Post 808577 by Blackdog on 2017-01-08 09:20:25
P1 and yes a straight fit. Other models may fit as well as I got mine from a late model old shape V40.
Post 808582 by jdavis on 2017-01-08 19:07:13
Something for me to look out for, the 850 ones are pants.
