Ecu woes, Turbo Tuner not playing ball...
Post 808788 by martin_r_smith on 2017-01-16 18:52:10
Just installed turbo tuner ecu on my 96 850 t5 using the base map provided but the car barely idles/stalls and the cooling fan is on continously. Put original back in and all is fine. The ecu came from a 96 850R auto so I would have thought compatability isn't an issue? Any ideas?
Post 808790 by Doingitsideways on 2017-01-16 20:45:29
It is M4.3 isn't it?
Post 808792 by Dangerous Dave on 2017-01-16 22:03:42
Have you checked the TT is compatible with your car/original ecu? Check the compatibility list on the TT website http://www.turbo-tuner.co.uk/
Post 808801 by martin_r_smith on 2017-01-17 06:23:45
It is 4.3. Well there aren't numbers on the ecu like the normal 0261........ But on their chart it does say a 96 850r auto is compatible with a 96 t5 auto.
Post 808802 by claymore on 2017-01-17 07:48:53
Have you tried loading a different map?
Post 808803 by JT on 2017-01-17 07:56:28
Cooling fan on continuous, is usually the sign the ecu has no map installed As Claymore says, install the map again or try another map.
Post 808806 by martin_r_smith on 2017-01-17 09:54:19
I'll try that and report back. Would it have fired up at all though if there was no map installed?
Post 808807 by Jamest5r on 2017-01-17 11:25:20
JT has copies of the Base stage 1 mte map I worked off, well he did a while ago :)
Post 808811 by JT on 2017-01-17 12:42:37
I have said map and have sent it over. :B_thumb:
Post 808812 by p fandango on 2017-01-17 12:52:19
[QUOTE=JT;808811]I have said map and have sent it over. :B_thumb:[/QUOTE] i've still got a copy of your last custom map for some reason
Post 808814 by JT on 2017-01-17 13:10:01
[QUOTE=p fandango;808812]i've still got a copy of your last custom map for some reason[/QUOTE] Just a back up, but wouldn't recommend that for Martins car........:hbomb:
Post 808816 by martin_r_smith on 2017-01-17 14:10:28
[QUOTE=JT;808814]Just a back up, but wouldn't recommend that for Martins car........:hbomb:[/QUOTE] It might go well................briefly :lol:
Post 808819 by martin_r_smith on 2017-01-17 15:55:39
Success! I loaded on a standard map and it works fine, for some reason it just doesn't like the turbo tuner supplied map. I will try the one you sent me JT but I have to wait for my registration with turbo tuner to be completed first so I can use the software fully.
