Post 809628 by Tee5alive on 2017-02-13 08:16:24
My old girl usually starts in SECONDS on the button, as they say. But for 2 days now she needs turning over for 20-30 seconds before firing?
There are no warning lights on or advisories? Filled her up 2 days ago and she hasnt moved. Her last run was back from Devon to Reading faultlessly cruising smoothly at motorway speeds.
Any clues please
Post 809644 by LeeT5 on 2017-02-13 18:10:18
Crankshaft sensor.
Which car? C70 or P26?
EML won't come on, but I bet, If you plug in a diagnostics tool, you'll have a code for CS.
Are you able to check live readings with any diagnostics? If so, look for engine speed signal - you should see 200-300rpm on crank.
Post 809663 by Tee5alive on 2017-02-14 00:07:53
Its my V70 Lee Harvey lent me a diag meter so I'll have a look thanks
Post 809665 by The Flying Banana on 2017-02-14 08:40:07
I had this before too...turned out to be the housing around the ignition key was packing up...one from another car ..pugged it in and it fired immediately
Post 809669 by LeeT5 on 2017-02-14 15:08:12
[QUOTE=The Flying Banana;809665]I had this before too...turned out to be the housing around the ignition key was packing up...one from another car ..pugged it in and it fired immediately[/QUOTE]
Transponder ring!
Indeed, that will give you those symptoms. It will also store immobiliser fault codes in the CEM!
Post 809670 by LeeT5 on 2017-02-14 15:09:22
You could see if there's any fault codes by checking the DIM, using the fog light switch/reset button.
Post 809901 by Tee5alive on 2017-02-22 14:37:13
[QUOTE=LeeT5;809670]You could see if there's any fault codes by checking the DIM, using the fog light switch/reset button.[/QUOTE]
OOh whats the gen on that Lee please?
Post 809902 by htomi on 2017-02-22 14:59:38
[video=youtube;x0MtY1BLbjQ]https://www.youtube.com/watch?v=x0MtY1BLbjQ[/video]
