Post 809978 by handyandyrta on 2017-02-24 08:18:54
Guys,
I am collecting a 2011 V50 D3 on mon/tues this next week and I will be wanting to get it re-mapped. Can anyone recommend where to get this done? Will be going for a power map + maybe map out the DPF.
I am in cumbria, but don't mind traveling to get this done.
Thanks in advance
Post 810003 by don kalmar union on 2017-02-24 18:11:37
During 2011 Volvo introduced a pincode system that prevents anyone from flashing aftermarket software into their vehicles' ECUs, The job has to be done , going back to the stoneage by opening the ECUs and flashing in through contact points on the circuit board.
This PINCODE BANDITRY is shocking in its scope allowing Volvo to profit from it to an extent that no other manufacturer has to date.
Against a cornerstone tenet of the EU, manufacturers should not exploit a dominant market position.
Don.
Post 810006 by LeeT5 on 2017-02-24 19:08:25
http://www.jrtuning.co.uk/index.shtml
This is the guy that mapped my car. He removed the ECU and 'pinned out' the chip to map it.
I highly recommend him.
Post 810174 by handyandyrta on 2017-03-02 16:12:45
Thanks for the replies. I have contacted Rob at JR Tuning and had an email craic with him.
Although since then there has been a change of plan, the D3 was a wreck, looked like it had been abused, so now looking at getting a D4 of the same year. Do these all have the DPF fitted now? And is there any mileage in getting this removed (sleeved inside) and deleted?
Post 810176 by LeeT5 on 2017-03-02 17:59:36
The laws on DPFs have changed considerably since they appeared on cars way back circa 2004 ish.
It's a massively grey area and you ultimately risk it failing an MOT, even if you delete the DPF through software.
The only performance gains to be met would be if you physically removed the DPF.
Otherwise, it begs the question, what is it you're trying to achieve?
If it's performance then why would you buy a Diesel V50?
Why not sell it and get a V50 T5? At least they don't have a DPF, so no mucking about.
Surely the point of having a performance car is getting one that's half way there already!?
Next your going to tell me it's a 1.6 diesel.....to which I'll reply, why bother?
Maybe I'm missing the point??
Post 810189 by don kalmar union on 2017-03-02 20:15:59
Were you to buy a pre '10 V50 D5 with a proper 5 pot diesel engine then I can offer you MTE's excellent software calibrations that you can flash in yourself through the OBD port. I still have that on my special offer at £355.
That gives pretty good enhanced outputs of 225bhp and a stonking 480nm of torque.
Don.
Post 810198 by handyandyrta on 2017-03-02 22:49:12
[QUOTE=LeeT5;810176]The laws on DPFs have changed considerably since they appeared on cars way back circa 2004 ish.
Maybe I'm missing the point??[/QUOTE]
I could tell you it's a 1.6, but that would be incorrect. It's the 5cyl 2.0 D4. I'm not wanting to delete the DPF for power gains, the straight fwd remap will give enough power for my Mrs to handle. My reason for wanting rid of the DPF is simply through experience of what trouble it caused with her previous V50.
Sent from my HUAWEI VNS-L31 using Tapatalk
Post 810199 by handyandyrta on 2017-03-02 22:55:02
[QUOTE=don kalmar union;810189]Were you to buy a pre '10 V50 D5 with a proper 5 pot diesel engine then I can offer you MTE's excellent software calibrations that you can flash in yourself through the OBD port. I still have that on my special offer at £355.
Don.[/QUOTE]
Thanks Don, depending on what this car is like on Saturday I might get back to you.
I take it that the 61reg that we're going to test on Saturday cannot have software just flashed in to it then?
Andy
Post 812071 by Yobbo on 2017-05-26 13:27:08
[QUOTE=LeeT5;810176]...Surely the point of having a performance car is getting one that's half way there already!?
Nowt wrong with an extra bit of grunt to go along with the fuel economy! ;)
