Handbrake Light not illuminating
Post 810741 by htomi on 2017-03-29 14:46:05
Just noticed, when I pull the handbrake the dash light doesn't illuminate. The dash light is fine as it turns on for few seconds once the ignition is in position II . Where is the switch located? Thanks!
Post 810743 by Dangerous Dave on 2017-03-29 15:33:58
From this pic it looks like it is located at the bottom of the lever pivot: Image Looks quite simple so should be easy to clean.
Post 810745 by htomi on 2017-03-29 16:06:53
Thanks! I'll try clean it first.
Post 810811 by htomi on 2017-04-01 17:04:06
Resolved. Solution; sanded the other end of the plastic pice - which holds the electric copper piece in place - to make it slide back and forth smoothly. Now, the copper shim connects perfectly when the handbrake engaged.
