stripped security wheel bolt = joy
Post 811838 by edde on 2017-05-14 15:32:28
so the title gives it away fairly quickly, the security key looks to have shat the bed due to some delightful air gun armed maniac. This has left me with two queries, what solutions have others found for this situation? Secondly, are there any recommendations for a durable set of replacement locking keys/bolts? If it helps, the wheels are tethys and the security bolts are what came fitted from the factory. Also, I googled this to death so I'm aware of welding on nuts, smashing smaller sockets on etc etc, I was just hoping some other poor soul has experienced the same but rectified it with more finesse lol. Many thanks in advance!
Post 811840 by MoleT-5R on 2017-05-14 16:13:18
Nope....I just smashed a socket onto it to remove it ....no real finesse there and as for replacement I didn't, I just went back to standard bolts, my theory is that if they really want to nick your wheels these days they'll most probably pinch the car to start with and strip it somewhere else and then probably torch it...:(
Post 811841 by M-R-P on 2017-05-14 17:01:55
Imperial socket wrapped in tape. Lots of tape, so it doesn't fit in the bolt recess. This stops it bouncing out when you hit it with a hammer.
Post 812035 by edde on 2017-05-23 16:07:30
Just a quick update, after discussing this with FRF while ordering some parts, Mike kindly directed me where to go in order to navigate the mcguard website so I could get a replacement key. After scrabbling around in the cars paperwork I found the code and Julien date, and after a few forms and 16 or so euros it was done. A few days later and the new key arrived, only then by comparing it with the old one could you see how chewed up it was. Armed with the new key and a breaker bar the security bolts are off, there was a worrying crack removing them which did leave me a little worried I'd snapped my lovely shiny key, but that turned out to be the rust unbinding. A quick clean with a wire brush, a small dab of copper slip and I snugged them back up. Jobs a good'un. So if you find yourself in the same situation, and have the codes you can get a replacement key very easily. Failing that, if the keys were original to the vehicle, mcguard can provide replacements but you need to prove ownership, vin numbers iirc to order them.
Post 812036 by claymore on 2017-05-23 17:00:00
Why on earth would you put them back on, just use normal wheel bolts.
Post 812037 by edde on 2017-05-23 17:14:42
My wheels are super rare and need protection. 180k kerbed and peeling tethys wheels are on trend, it's the car equivalent of shabby chic. Jokes aside the bolts were fine, got a brand new key and I've taken steps to minimise binding. Plus I'm going to start threatening tyre fitters with taking the blood of their first born if they over torque them.
Post 812039 by htomi on 2017-05-23 19:19:12
Tyre fitters love to use their air impact wrench and then over torque wheel bolts with a big f***** spanner. This makes nearly impossible to take off the wheel with the supplied emergency tools. I got rid off the security bolts on all cars of ours. No point. If someone wants to take the wheel, the'll do it no matter what...
Post 812045 by 960kg on 2017-05-24 09:00:21
There is really no need anymore for these security wheel bolts as most modern cars including the early V70 i had was fitted with the Tilt Sensor and if jacked up the alarm goes off......
Post 812047 by edde on 2017-05-24 10:14:40
Lies, don't you remember in Twins when Arnie lifts up the 5.0 Mustang convertible to turn off the alarm because the car thinks it's getting towed. Films, never, lie. It's an interesting point though, I might see if mine goes off when doing the drop links.
Post 812048 by Gold 'N' Brown on 2017-05-24 11:37:54
My V70 is the first car I've had where I've not bothered fitting security bolts (even though I had the wheels refurbed and new tyres fitted in the first year). I just don't see the point anymore. Certainly around here I don't think wheel theft is the done thing anymore (the yoof of Edinburgh are either stealing motorbikes and riding them around Granton or they are involved with the break and enter gangs stealing performance cars to order). That said, I've never had a problem with stuck bolts so you should be fine* refitting those if the threads are OK and the the key fits OK. Just do what I do, if you ever have a garage put the wheels back on for any reason, loosen them up yourself as soon as you get home and tighten to the correct torque. That way if they've been a gorilla you can go straight back and get them to do it properly. *Edited to add, I think the main reason I've never had a stuck bolt is that I usually have my wheels off at least once per year for maintenance/MOT checks etc. A bit of a generalisation but I reckon most of the time the problems are a mix of overtightening (garage gorillas) and corrosion where a wheel hasn't been off the hub in years.
Post 812049 by p fandango on 2017-05-24 15:44:12
i had to grind the head off the locking nuts on my old S60, tried 3 different tyre shops who couldn't get it undone Image
Post 812052 by Doingitsideways on 2017-05-24 19:00:29
[QUOTE=p fandango;812049]i had to grind the head off the locking nuts on my old S60, tried 3 different tyre shops who couldn't get it undone Image[/QUOTE] That where James got the idea?! :lol:
Post 812060 by Gold 'N' Brown on 2017-05-25 13:25:42
Bit of chemical metal and a dash of silver paint and it'll be right as rain again.
Post 812063 by p fandango on 2017-05-25 14:35:53
might need some gorilla tape for the other side, got fed up of the rim being in the way so cut that off 1st before grinding the head off Image Image
Post 812065 by htomi on 2017-05-25 19:23:33
Custom made flower pot. Supported by Volvo :-)
Post 812068 by rs_andy on 2017-05-25 21:14:55
Good grief, I felt hard done to when I had my locking bolts drilled out after them being fitted by an ape and they only took a chunk out of the paint! ....and 250 notes out of my back pocket. Sent from my iPhone using Tapatalk
