Rear most exhaust hanger bracket
Post 811922 by Bigsi15 on 2017-05-18 13:16:40
Hi guys anyone any experience of changing the rear exhaust hanger? Mine is very rusty but speaking to Volvo it seems there are a few issues... I have the bracket made up of a bracket bolted to a plate which is bolted to the chassis looking like this [ATTACH=CONFIG]31579[/ATTACH] Then with the bracket bolted to it [ATTACH=CONFIG]31580[/ATTACH] It appears the hanger part is no longer available and so is replaced by this [ATTACH=CONFIG]31581[/ATTACH] From what I have read this just bolts to the chassis as one unit removing the need for the middle spacer bracket I was wondering if anyone knew if this affects how high the exhaust is held (what with a middle bracket now missing) and does it fit with the standard mounts and rubbers? I'm pretty sure it isn't compatible with that mid bracket Thanks!
