volvo 240 gl v8 project
Post 812139 by jimperry on 2017-05-29 16:14:14
[ATTACH=CONFIG]31594[/ATTACH][ATTACH=CONFIG]31595[/ATTACH] Hi all Had this a while now and thought i had better get on it the unfortunate jaguar 2002 4.0 sc xjr 308 cane along mechanically sound but tin worm had had a busy time on the body, and was deemed uneconomical to repair quite a lively old bus 370 bhp 380lb ft toque with a merc 5 speed box. as a friend of mine had offered me the volvo in a deal with some other stuff, got to thinking a quick look at the engine bay monstrous space that v8 jag would look good in there me thinks! 2 painstaking weeks stripping the jag and thinning the loom to a minimum so it can still run engine and gearbox still a big box of wiring tho, got the engine and gear box fitted fabricated mounts, using a 940 turbo prop fits both ends just need shortening 40 mm wondered if any one else on here has fitted a jag engine as they are available in all shapes and sizes for not very much any input or ideas greatly appreciated
Post 812140 by claymore on 2017-05-29 16:57:54
Can't answer your question, but I'm very much looking forward to updates on this one.
Post 812143 by jimperry on 2017-05-29 17:48:47
[ATTACH=CONFIG]31596[/ATTACH][ATTACH=CONFIG]31597[/ATTACH][ATTACH=CONFIG]31598[/ATTACH] Hi few more pics off to get prop shortened tomorrow will also get a 16 toothed wheel just behind the front joint this is needed for gear box ecu to know road speed the jag has 3.06 diff 48 tooth abs pick up divided by 3 ish. road speed taken from back wheels (3 turns of prop to 1 of road wheel) the gearbox ecu knows the in and out shaft speed and compares it to the road speed if it don't like what it sees it defaults to limp mode this could be the hardest bit to get right
Post 812144 by Doingitsideways on 2017-05-29 17:52:33
Ooohh... I do love a dirty V8. Keep the updates coming, not forgetting the obligatory start up vid with half an exhaust :D
Post 812145 by jimperry on 2017-05-29 18:04:05
i still love my old 850r estate sweet 5 pot[ATTACH=CONFIG]31599[/ATTACH]
Post 812146 by jimperry on 2017-05-29 18:05:53
just realized that was 2012 time flys
Post 812174 by petrolh34d on 2017-05-30 10:41:32
Looking forward to this :)
Post 812179 by Tomcat on 2017-05-30 20:00:40
Ooof!!! Nice project!! looking forward to updates!!
Post 812219 by jimperry on 2017-06-01 21:20:36
Hi thanks for the encouragement, stripped the interior today the dash has a lot of bits haha[ATTACH=CONFIG]31604[/ATTACH] connected all the v8 wiring loom together for a compare[ATTACH=CONFIG]31605[/ATTACH] the good thing is the bulkhead has a huge plate that can be removed makes life a bit easier,removed the volvo wiring loom as well the old bullet fuse box has seen better days i might remake a simplified one with the basics. dont know what state a 1988 volvo is usually like rot wise this one seems quiet good apart from a 2 inch hole under the rear seat and same in inner rear wheel arch the other issues are fuel tank it dont fit in the boot, it is a twin immersed pump type i may cut the top out and make small a swirl pot tank with the pumps inside fed from the old tank ecu gets upset if different pumps are used as they are pwm type ,and the radiator is to tall i have a 850 r one so i may try to fit that[ATTACH=CONFIG]31606[/ATTACH] any other ideas for a radiator type would be appreciated cheers jim
Post 812220 by jimperry on 2017-06-01 21:26:38
[ATTACH=CONFIG]31607[/ATTACH][ATTACH=CONFIG]31608[/ATTACH]
Post 812233 by jimperry on 2017-06-02 16:38:36
HI looks lice a 850r rad will do the job will use the jag twin fans[ATTACH=CONFIG]31610[/ATTACH] had a bit of a chopping spree on gear box tunnel lowered the gear lever mount 60mm to accommodate the taller larger shifter assy[ATTACH=CONFIG]31611[/ATTACH][ATTACH=CON FIG]31612[/ATTACH] thats all i managed today as the argon gas ran out and the weather has now taken a turn for the worse cheers jim
Post 813738 by jimperry on 2017-09-13 22:26:35
[video]VID 20170911 WA0003[/video] first start a way to go as yet
Post 813743 by claymore on 2017-09-14 07:59:06
[QUOTE=jimperry;813738][video]VID 20170911 WA0003[/video] first start a way to go as yet[/QUOTE] Try this: [video=youtube;lI4kK33lhRw]https://www.youtube.com/watch?v=lI4kK33lhRw[/video]
Post 813750 by Timo. on 2017-09-14 16:23:24
MMMMmmmm........ v8 sound. Nice!!!
Post 813774 by jimperry on 2017-09-16 23:02:00
Thanks for that Claymore Have been busy lately and have not had time to do much a quick update the main problem i had was a gear box ratio fault due to the diff ratio the jag was a 3.06 and the volvo i believe is a 4.27 the internal speedo pickup on the diff is 48 tooth same as the jag abs rings due to axle ratio the difference is to much and the gear box ecu assumes there is clutch slipping internally and fail safe is set, so i figured 48 divided by 3 roughly 16 teeth on prop should do it, set about the diff flange with a file and grinder[ATTACH=CONFIG]31787[/ATTACH] added a 850 rear abs sensor on a small bracket it seems happy and gearbox works ok think i will have to find a 3.6 diff or there abouts at a later date ,[ATTACH=CONFIG]31788[/ATTACH][ATTACH=CONFIG]31789[/ATTACH]also added a small fuel secondary tank to house the twin jag pumps
