T5 abs unit?
Post 812214 by Jofenan on 2017-06-01 20:14:17
Got myself a t5 last week. Just done a service and found something odd under the bonnet. There's a unit on the right hand side of the engine with a number of brake pipes coming out of the top of it. I'm guessing it's an abs unit? Towards the front of the unit there's a black plastic cover. Here's the strange thing. Someone at sometime has jammed what looks like 3 library/shell cards in the gap between the black plastic cover and the brake pipes. Any idea why?
Post 812217 by MoleT-5R on 2017-06-01 20:39:33
nope, but if it's all working fine, I'd suggest that you leave it there, but I would check that the abs trac lights still work on the dash correctly first and not had the bulbs removed, the abs is prone to electronic faults which normally are dry solder joints and are usually a cheap fix.
Post 812218 by Jofenan on 2017-06-01 20:48:01
Will leave it alone! Good job I have my own shell card :)
Post 812248 by Rogerb on 2017-06-04 03:06:37
The pins on the socket come lose on the printed circuit board. Normally means taking it apart and re-soldering the connections. By wedging it to has possibly fixed the ABS . Normally only temporary fix. As in above reply. Not too bad to fix properly. Roger.
Post 812272 by Wobbly Dave on 2017-06-05 14:14:11
I still repair them and you can then remove/keep the library cards
