Post 812734 by macV70R on 2017-07-03 14:12:46
Going to be doing a stage 0 on the V70r, as far as I know the car is currently standard. Can anyone recommend any other improvements/upgrades to be done at the same time ?
[QUOTE=macV70R;812734]Going to be doing a stage 0 on the V70r, as far as I know the car is currently standard. Can anyone recommend any other improvements/upgrades to be done at the same time ?[/QUOTE] List is not exhaustive but should include... PCV replacement (In full) includes Inlet manifold gasket. Thermostat housing (which includes temp sensor) This will include drain and refill of Coolant. Auxillery belt + tensioner idler Smoke leak test to determine any leaks prior to stage '1' and to complete stage '0'. (this is vital as it will expose any leaks that are not seen with the naked eye) Remove and fully clean PCT nipple. Replace both one way valves. Replace injector 'O' rings x8 (to be done at the same time as PCV system) I also recommend a Terraclean. (this will save money buy not having to send injectors away for cleaning and will also clean Valves, piston heads, Catalyst etc, etc)
