Post 813034 by Sam-C30-AWD on 2017-07-21 20:33:57
My 2007 C30 started out as a standard T5 Slowly started adding bits and pieces !!
[ATTACH=CONFIG]31679[/ATTACH]
[ATTACH=CONFIG]31680[/ATTACH]
[ATTACH=CONFIG]31681[/ATTACH]
[ATTACH=CONFIG]31682[/ATTACH] Port and polished lower manifold !
[ATTACH=CONFIG]31683[/ATTACH] Custom 76mm intake !!
[ATTACH=CONFIG]31684[/ATTACH] Upper inlet manifold fitted !!
[ATTACH=CONFIG]31685[/ATTACH] Mazda 3 front brake kit with new discs and red stuff pads !!
[ATTACH=CONFIG]31686[/ATTACH] M66 AWD gearbox
[ATTACH=CONFIG]31687[/ATTACH] Angle/transfer box
[ATTACH=CONFIG]31688[/ATTACH] Running gear parts painted black
[ATTACH=CONFIG]31689[/ATTACH] Gearbox with transfer box on !!
[ATTACH=CONFIG]31690[/ATTACH] Gearbox cleaned and in primer !!
[ATTACH=CONFIG]31691[/ATTACH] [ATTACH=CONFIG]31692[/ATTACH] Gearbox Painted black !!
[ATTACH=CONFIG]31693[/ATTACH] Prop carriers painted black !!
[ATTACH=CONFIG]31694[/ATTACH] Rear subframe cleaned, primed and painted yellow !!
[ATTACH=CONFIG]31695[/ATTACH]
Looking an interesting build
Had it for 4 years just been doing bit my bit got most of the AWD swap done Just gotta get the AWD harness wired into my loom and possible software needed , This was my AWD donor car [ATTACH=CONFIG]31696[/ATTACH] [ATTACH=CONFIG]31697[/ATTACH] [ATTACH=CONFIG]31698[/ATTACH]
[QUOTE=Sam-C30-AWD;813054]Had it for 4 years just been doing bit my bit got most of the AWD swap done Just gotta get the AWD harness wired into my loom and possible software needed , This was my AWD donor car How's the wiring look? Is it a straight forward thing?
[ATTACH=CONFIG]31699[/ATTACH] This was the section of AWD harness i removed from the V50 [ATTACH=CONFIG]31700[/ATTACH] [ATTACH=CONFIG]31701[/ATTACH]
This has to be wired into my car yet AWD running gear installed prop shaft fitted [ATTACH=CONFIG]31704[/ATTACH] AWD fuel tank [ATTACH=CONFIG]31702[/ATTACH] Had my DP Modified to fit [ATTACH=CONFIG]31703[/ATTACH]
Looks like your on top of things. Does the rear subframe fit up ok?
Everything is a direct fit no modification needed just take parts off and put AWD parts on !! I am the first individual person to do this swap and its the only one in the Uk ( road car )
Great project! Must be nice to have the tools/space to be able to do it :D One of my goals it to have a workshop and a lift :)
Looks an awesome project there. Always thought a properly set up C30 AWD would be an awesome tool to wipe the smile off the Focus ST/RS boys' faces :lol:
That's what I'm aiming for is to be able to get more grip, lol It's got a shark stage 3 tune for k04 standard turbo Makes 310hp And 510nm which I'm hoping will be good once the AWD is working
I also got a spare T5 engine with my donor car which is being Stripped cleaned Ect Hopefully build it stronger and go k24 hybrid The spare head is being ported and polished which should be good with both manifolds !!
How did this project go? I just bought a 6spd AWD V50 to convert my Automatic C30! Teardown should begin tonight.
Love this project c30. Love to see a video when it's finished. Do you think this would work on a v70 2009 2.5t
Hello, i dont own a volvo but i have just done the exact same conversion on a focus st using the same parts as both the c30 v50 and mk2 focus are all identical underneath. i found your thread very useful and im just wondering if you managed to finish yours, if not let me know have any issues as iv managed to get it all working.![]()
