V70R p1 FWD rear suspension
Post 813834 by Muzzleflash on 2017-09-20 19:38:12
Hello first post. Does a 97 V70R fwd have nivomat suspension?? Thank you in advance.
Post 813839 by stribo on 2017-09-21 09:05:50
Yes.
Post 813856 by rs_andy on 2017-09-21 20:35:46
[QUOTE=stribo;813839]Yes.[/QUOTE] Wouldnt have thought so, certainly not as standard Sent from my iPhone using Tapatalk
Post 813858 by Quicksilver on 2017-09-21 22:31:11
Mine has.
Post 813860 by Muzzleflash on 2017-09-22 00:08:39
[QUOTE=rs_andy;813856]Wouldnt have thought so, certainly not as standard Sent from my iPhone using Tapatalk[/QUOTE] They did unfortunately - but I'm converting it to standard shocks, with uprated springs., 1/8th the price of new (extraneous) Nivos.....
Post 813864 by Quicksilver on 2017-09-22 10:34:20
[QUOTE=Muzzleflash;813860]They did unfortunately - but I'm converting it to standard shocks, with uprated springs., 1/8th the price of new (extraneous) Nivos.....[/QUOTE] I would probably do the same if they were to go faulty but I use mine for towing and carrying and the self leveling is handy.
Post 813882 by LeeT5 on 2017-09-24 08:22:42
My P1 V70R AWD 1999 had Nivomats on the rear and they worked incredibly well! From memory, Nivomats were NOT standard but an option due to the cost...almost double that of a standard shock. Easiest way to check is to look under the car, but if you don't know what your looking at then give your Dealer a ring, tell them your Reg and they will be able to tell you everything you need to know. Anyone with VIDA can also tell you , as it will list the build spec of your car from new.
Post 813895 by foammanmark on 2017-09-24 19:47:46
Sometime early 2018 I will have a pair of Nivo's for sale. Due to a BC coilover 'breaking', I have Nivo's on the rear of my C70, but she sits too high, so a new BC strut and the Nivo's will be spare.
Post 813900 by claymore on 2017-09-25 08:21:20
[QUOTE=LeeT5;813882]My P1 V70R AWD 1999 had Nivomats on the rear and they worked incredibly well! give your Dealer a ring, tell them your Reg and they will be able to tell you everything you need to know. Anyone with VIDA can also tell you , as it will list the build spec of your car from new.[/QUOTE] That's assuming they haven't been changed in the 20 year life of the car.
Post 813901 by MoleT-5R on 2017-09-25 08:29:53
[QUOTE=claymore;813900]That's assuming they haven't been changed in the 20 year life of the car.[/QUOTE] Yes that is true, anything could have changed since the car was built, so the Vida build spec may not be totally correct, so as Lee said he may need to know what he's looking for... Whilst on the Nivo subject and also for the OP's information, are the top mounts different for nivo and non-nivo setups ?? I believe there are 2 different part numbers but can't recall actually seeing any differences in any top mounts that I have here.
Post 813902 by claymore on 2017-09-25 08:51:40
[QUOTE=MoleT-5R;813901]Yes that is true, anything could have changed since the car was built, so the Vida build spec may not be totally correct, so as Lee said he may need to know what he's looking for... Whilst on the Nivo subject and also for the OP's information, are the top mounts different for nivo and non-nivo setups ?? I believe there are 2 different part numbers but can't recall actually seeing any differences in any top mounts that I have here.[/QUOTE] Yep, top mounts are different, so you have to replace shocks, mounts and springs.
Post 813992 by Muzzleflash on 2017-09-30 08:18:06
[QUOTE=claymore;813902]Yep, top mounts are different, so you have to replace shocks, mounts and springs.[/QUOTE] Now all done using new mounts, standard shocks and Lesjofors uprated coils. 👍
