98 V90 stall
Post 813877 by Reignmaker on 2017-09-24 01:21:34
Hi everyone. My v90 2.9 is stalling, without going dead. Usually a couple minutes after start, it will puke out after taking off from a stop, no lights come on or error codes just a lack of pedal then it roars back after a couple of seconds. Anybody have this occur? So far I have replaced the mass air flow and it doesn't seem like an injector issue. Thoughts? Sent from my iPhone using Tapatalk
Post 813889 by Dangerous Dave on 2017-09-24 17:12:26
Possible fuel starvation issue? Something in the line like dodgy fuel pump, blocked fuel filter or bad fuel pressure regulator.
Post 813890 by Reignmaker on 2017-09-24 17:32:25
[QUOTE=Dangerous Dave;813889]Possible fuel starvation issue? Something in the line like dodgy fuel pump, blocked fuel filter or bad fuel pressure regulator.[/QUOTE] Hi Dave, you are thinking along the same lines as I am. I replaced the fuel pump already, and was thinking filter and regulator should be next. Thanks for the input. Sent from my iPhone using Tapatalk
Post 813920 by Dangerous Dave on 2017-09-25 22:07:28
The filter is a cheap and easy item to replace and should be done if it hasn't been done for a long time anyway
Post 813934 by Reignmaker on 2017-09-26 18:11:57
[QUOTE=Dangerous Dave;813920]The filter is a cheap and easy item to replace and should be done if it hasn't been done for a long time anyway[/QUOTE] I just did the pump a few months ago, I have the regulator and filter arriving today. We will see if it fixes this. Sent from my iPhone using Tapatalk
Post 813949 by Dangerous Dave on 2017-09-27 15:51:44
[QUOTE=Reignmaker;813934]I just did the pump a few months ago, I have the regulator and filter arriving today. We will see if it fixes this. Sent from my iPhone using Tapatalk[/QUOTE] Cool, let us know how you get on :)
Post 813954 by LeeT5 on 2017-09-27 19:50:32
Start cheap! Have you tried cleaning the throttle assembly out? Any fault codes? Fuel pressure regulator would cause a fault code to be logged, as would a blocked fuel filter. If the car then drives fine, even under, after the initial stall, then I very much doubt its the filter.
Post 814017 by Reignmaker on 2017-10-01 19:51:48
[QUOTE=LeeT5;813954]Start cheap! Have you tried cleaning the throttle assembly out? Any fault codes? Fuel pressure regulator would cause a fault code to be logged, as would a blocked fuel filter. If the car then drives fine, even under, after the initial stall, then I very much doubt its the filter.[/QUOTE] It’s not so much a stall as it just goes flat. No pedal, like a long hesitation. No lights, no codes. I have my parts (filter and pressure regulator)and am trying to find time to get out there and install, next day or two. Thanks for the comments. Sent from my iPhone using Tapatalk
