Post 814809 by Mr Sheen on 2017-11-22 15:03:28
I've got a broken wire on the O/S front ABS sensor wiring.
I want to trace it back, does it have a connector further up in the engine bay or does it terminate
at the ABS controller connector on the ABS pump?
Post 814850 by woz on 2017-11-29 22:43:39
[QUOTE=Mr Sheen;814809]I've got a broken wire on the O/S front ABS sensor wiring.
at the ABS controller connector on the ABS pump?[/QUOTE]
there is a connector inside the bonnet area, a bit fiddly to feed through with the plug on the end. Had to do it myself due to frayed wire internally where it went through the wing. Got not pics, but a splice and solder up and it all worked fine. The sensors tehmselves rarley gpo, its usually the wiring.
Post 814914 by Mr Sheen on 2017-12-05 21:38:50
Thanks Woz, I'll try and hunt down the connector location. It's definitely a broken wire. Sensor resistance is fine.
