Post 815090 by Gold 'N' Brown on 2017-12-27 15:12:12
Sorry for the ££££e topic title! :redface:
Can anyone with a Ph2 please check if possible (or confirm if you already know conclusively).....can you read the engine coolant temperature using an OBD ELM and Torque Pro or similar diagnostic software? Reason I ask is that I'm not seeing a reading on mine on either Torque Pro or OBD Car Doctor Free. It seems like it should be available, but I just get a stable 0 reading, and no errors. I just want to establish if this indicates a problem I need to deal with, or if it's simply that these apps can't get that reading from the ECU so nothing to be concerned by.
The dash gauge is reading fine, so the ECU must be reading the sensor OK.
Post 815092 by Dangerous Dave on 2017-12-27 15:26:31
I can read the engine temp on my 850 and my P1 V70 via torque pro and a bluetooth ELM reader so I'd have thought the P2 would be able to.
You can select the logged PIDs via the settings menu in torque pro, maybe it's not selected?
Post 815112 by Gold 'N' Brown on 2017-12-28 22:07:24
I did some googling and found a few mentions of this on other forums in relation to S60s and V70s, which confirm that other people are getting a reading for coolant temp on Torque Pro. Which makes it all the more frustrating for me.
I tested the sensor earlier, just unclipping it to check for any affects. Idle speed immediately changed and of course the ECU logged an error, which Torque displayed. Likewise the dash gauge dropped to zero when the sensor was disabled. I realise that doesn't prove that the sensor is providing a true reading to the ECU, but at least I know it's doing something. Torque Pro just shows a constant 0 no matter what the temperature is.
In terms of PIDs, I think it displays active PIDs (those that are able to provide any data at that time) in the list by highlighting them with a bright green background, whereas inactive sensors are not highlighted against the standard black background. But some of them (GPS related stuff being one example) are highlighted in a paler shade of green, and that is the case for the 'ENgine Coolant Temperature' as well.
I'll give Torque support a try and see if they have any ideas. Only other thing I can think of is maybe it's some sort of limitation due to the cheap ELM adaptor.
Post 815114 by Blackdog on 2017-12-29 10:52:45
I'm using a eBay cheap ELM adaptor and Torque. I can confirm that engine coolant temp is shown. Oil temp however is not.
Post 815116 by 960kg on 2017-12-29 12:56:43
Everyone too their own ...but this Torque pro i have used for quite a few years and one day with my V40 T4 the temp. showed 133 C and did i panic as i had just plugged it in after a very quick run.
The temp. on the guage and the feel on the engine cover showed it too be just normal.
So i never ever trust the Torque for anything just error codes.
Just saying so i wouldn`t myself worry if you can`t get the temp. come up ,it may just be a box that has to be ticked in Settings?
Post 815127 by Dangerous Dave on 2017-12-30 16:56:10
[QUOTE=Blackdog;815114]I'm using a eBay cheap ELM adaptor and Torque. I can confirm that engine coolant temp is shown. Oil temp however is not.[/QUOTE]
You can add custom PIDs in Torque, I was reading something about Volvo and oil temps but didn't look too much into it as I mine doesn't do it.
