Post 817772 by dibble34 on 2018-11-27 20:36:19
Hi All, i wonder if anyone can help.
My car has just had a new clutch and flywheel fitted at a very reputable garage, but there are problems and the car is still there. Basically as i understand it, the car was hard to shift into gear after the clutch was changed, both with the engine on or off. The shifter mech has been replaced with a good 2nd hand unit and so have the cables. This made it much better when not connected to the gearbox, however it is still a problem with the linkage connected. As i understand it now, it is hard to get into 6th gear only and after trying 6th, other gears are then stiff. All gears are ok with the engine off.
We are now looking at having to try another gearbox, however the problem was not there before the clutch was replaced. Does anyone have any ideas other than the gearbox before i start crying.
Post 817773 by Harvey on 2018-11-27 22:10:13
I there is some sort flow control unit the concentric slave unit , what make of clutch kit was fitted also did they do the flywheel..
there are two kits they have fitted the correct one it changed on 2005 MY cars .
Post 817774 by dibble34 on 2018-11-27 22:37:49
All Volvo parts and defo right kit fitted, mines a 2003. Flywheel also changed, such a weird problem. New control cylinder too
Post 817775 by Harvey on 2018-11-27 22:42:43
wondering if cables are are at fault or not quite in the correct position ?
Post 817777 by dibble34 on 2018-11-27 22:53:25
Cables changed and checked, gear selector changed too
Post 817796 by LeeT5 on 2018-12-01 13:55:01
[QUOTE=dibble34;817774]All Volvo parts and defo right kit fitted, mines a 2003. Flywheel also changed, such a weird problem. New control cylinder too[/QUOTE]
Assuming you've had Volvo parts fitted??
If so, the correct clutch kit for your 2003 car is: #30783258. That will include a CSC (Concentric Slave Cylinder).
Was the flywheel fitted a DMF or SMF?
Post 817800 by dibble34 on 2018-12-01 19:20:09
All Volvo, new dmf as well. Looks like gearbox, fitting a replacement next weekend hopefully. Those part numbers match my bill
Post 817803 by MoleT-5R on 2018-12-02 14:06:49
[QUOTE=dibble34;817800]All Volvo, new dmf as well. Looks like gearbox, fitting a replacement next weekend hopefully. Those part numbers match my bill[/QUOTE]
nothing worse that getting it all back together, to then find you have to strip it all back down again, I had to do that when I fitted my 2.0L 10v gearbox to my olive T-5R, but that was all my fault and not really the gearboxes, it was only trying to tell me that it prefers to work with some lubrication in it.....:rotfl::lol::cuckoo:
