Post 818550 by simonc on 2019-05-25 18:41:30
I typed title incorrectly lol sorry. My T-5R is running 4.4 ECU and I want to convert to OBD2 port, can anyone help and tell me what I need to do? Obviously a OBD2 port and sone wiring but not sure how to do it as can’t find anything on the net.
Simon
Post 818551 by Dangerous Dave on 2019-05-25 22:48:30
Is it the non immobiliser M4.4 ecu? If so you should be able to run a wire from pin 7 on the OBD connector to pin B36 on the ecu. Then standard OBD pin 4 to ground and OBD pin 16 is +12V.
Check this thread out
https://www.matthewsvolvosite.com/forums/viewtopic.php?t=77600
Post 818553 by simonc on 2019-05-26 09:45:04
Thanks for the reply.
How will I know if it’s non immobiliser ECU?
Post 818555 by Dangerous Dave on 2019-05-26 13:53:27
[QUOTE=simonc;818553]Thanks for the reply.
How will I know if it’s non immobiliser ECU?[/QUOTE]
Depends on who fitted it and what they did to it. If it has been flashed with the non immobiliser map then it will work. But if someone just put a normal m4.4 ecu in then it won't work (unless it is the non immobiliser version of that ecu).
Did someone else fit it then?
Otherwise there is no way to tell without reading the eprom in the ecu.
Post 818557 by simonc on 2019-05-26 14:19:11
Ah ok right. I’m ok doing mechanical work and a bit of wiring but know zero about ECU’s and reading codes etc. Hence wanting to fit OBD2 port myself so I can read the codes and have more understanding and be able to maintain the car in full myself.
I know the previous owner had Shemtek put the tune on the car and quite a bit of work done there. Shem has offered to help so I’m going to ring him in the week. Another reason for wanting OBD2 is to go to the next stage of larger injectors, new fuel pump and MAF but I know OBD2 port is needed for mapping at that stage.
Simon
Post 818558 by Dangerous Dave on 2019-05-26 15:34:06
It's possibly the non immobiliser version then if Shem has mapped it. But yeah have a word with him as only he'll know.
Post 818579 by simonc on 2019-05-30 08:49:28
Haven’t been able to get hold of him this week. Maybe he’s on holiday. Will try next week.
Assuming it’s not immobilised, all I need is a female 16 pin socket and some wire?
I’ve read it’s 3 wires,
1. Earth
2. Live, switched or perminant?
3. Wire to ECU but which pin? I’ve read some say B36 some say B5 or maybe that’s wrong.
What code reader would I need to buy, only want to read engine fault codes.
Post 818597 by Dangerous Dave on 2019-06-01 23:10:32
Live is usually permanent on the OBDII socket.
As for a reader a cheap Bluetooth one of eBay will suffice and download Torque app to connect your phone to read the codes.
I'll see if I can dig out the wiring diagram so you can see which pins to connect to
Post 818624 by simonc on 2019-06-03 17:38:06
I found a link in this thread
http://www.vpcuk.org/forums/showthread.php?56982-Converting-OBD1-too-OBD2
which has the diagram, will have a go later in the week as I’ve got my OBD 16 pin female port now. Just got to work out where I want it in the car and run wires.
What’s the best way of getting to the back of the ECU plug to get to pin B36? Do you know if their is already a wire connected to that pin that I could tap into. I’m a bit worried of disturbing the loom as it’s old. I can see you just lift out the ECU but not sure how to get to the back of plug/loom.
Post 818637 by simonc on 2019-06-05 18:57:43
I’ve wired in the live and earth to OBD2 socket just got to run wire through to ECU. Decided to put it in the glovebox. What’s the easiest way to connect a wire to B36? Does the ECU housing just lift out or can I just tap into a wire coming off B36?
Post 818667 by simonc on 2019-06-09 21:55:26
This may help others who want to wire in OBD2 port as I struggled to find any info.
Post 818772 by simonc on 2019-07-16 13:26:36
Finally finished install and got it working ok, can read codes etc with Torque app now.
Post 818773 by kmb on 2019-07-16 14:18:52
Good news, any noticed differences?
I was running my 850 T5 on a mapped M4.4 (done by Oblark on here) and it seemed to run much more smoothly and of course more power on the mapped M4.4, with the added bonus of being able to read and reset codes etc. with Torque App.
Post 818791 by simonc on 2019-07-19 17:46:57
It was already on a mapped 4.4 by Shemtek when I bought it. All I’ve done is wire in a OBD2 port to read codes. No codes stored. Should be useful though as when I take it to the rolling road they will be able to check the AFR through port as last time they couldn’t check.
Post 818792 by Dangerous Dave on 2019-07-19 22:13:27
Has it got the wideband mod then?
Post 818794 by simonc on 2019-07-20 15:24:21
[QUOTE=Dangerous Dave;818792]Has it got the wideband mod then?[/QUOTE]
All I did was run wire to B36 and then earth and live. Can read codes ok. Is their more I need to do? Just assumed they could check my AFR through OBD port. I’m not really up on all this stuff but trying to learn.
Post 818795 by Dangerous Dave on 2019-07-20 15:49:15
No worries, there's lots to learn :)
Unfortunately it is not possible to read the AFR from the standard ecu as it uses a narrowband O2 sensor which can't read a wide range of AFR. So AFR is not an option via OBD2. You can read the fuel trims and sensor voltages but as it runs on an old OBD protocol the refresh rate is dog slow.
To get full fast AFR (and other parameters) value streaming you need to have the modified ecu binary that the Volvospeed guys have been developing and have a wideband O2 sensor fitted.
More info here:
https://m44.fandom.com/wiki/M44_Wiki
