ABS fault?
Post 820835 by David P on 2021-01-08 18:55:39
My C30 D5 has recently had new callipers, discs, pads and flexi hoses fitted yet despite no errors lit up on the dash, my BSR diagnostic informs me there is a problem? BCM - BRAKE CONTROL MODULE 0x0041 Wheel sensor right rear Incorrect signal 0x0031 Wheel sensor left rear Incorrect signal Does anyone know what this could be?
Post 820850 by David P on 2021-01-11 17:35:00
Excuse me for bumping this, but I was really hoping that someone would be able to furnish me with more specific information for this fault code?
Post 820853 by merc85 on 2021-01-11 20:35:56
Abs sensor? /Wheel bearing , Complete hub assembly i believe. Just a possible, Have you plugged them back in or disturbed the wiring?
Post 820854 by David P on 2021-01-11 21:30:38
I haven't done anything, other than to pay a Monkey Nic to fit a pair of new callipers and pads. I don't understand what he could have done wrong with such a simple job?
Post 820861 by Dangerous Dave on 2021-01-12 17:56:21
Sounds like they might have disturbed the abs connectors when changing the calipers.
Post 820870 by David P on 2021-01-13 16:16:44
That does sound the most likely. Thank you. Maybe "Incorrect signal" is Swedish for "No signal" ?
Post 820932 by David P on 2021-01-26 18:06:18
It turns out that the Monkey Nic had left the ignition on, or had turned the ignition on during the calliper change. To discover this and to delete the consequent fault code entailed a diagnostic check @ £49.95 plus 20% VAT.
