Post 821282 by azatoglu on 2021-04-30 07:29:25
Hi , I am an old Volvo forum member in volvospeed and ipdforums.I own 2004 V70 2.0T which is now 247.000km.I have a faulty auto gearbox and with the help of these volvo forums I am still using it in the last 100.000km with no big problems.Thanks
Post 821283 by LeeT5 on 2021-04-30 09:45:10
[QUOTE=azatoglu;821282]Hi , I am an old Volvo forum member in Volvospeed and ipd forums .I own 2004 V70 2.0T which is now 247.000km.I have a faulty auto gearbox and with the help of these volvo forums I am still using it in the last 100.000km with no big problems.Thanks[/QUOTE]
Hi and welcome.
What exactly is the fault with the gearbox, or don't you know?
Post 821291 by azatoglu on 2021-05-01 06:23:11
Thank you :)
As I learned from these forums the gearbox in our cars P2 V70 between 2000-2004 are prone to failing so when I got the car the owner is having problems like knocking and flares.After I got the car I changed the fluid to Mobil 3309 and make the B4 cover upgrade , make the adaptation and most importantly added a trans cooler and a filter.Now after 100.000km it is still going strong.We will see how long it can last :)
Post 821303 by LeeT5 on 2021-05-03 09:14:57
[QUOTE=azatoglu;821291]Thank you :)
As I learned from these forums the gearbox in our cars P2 V70 between 2000-2004 are prone to failing so when I got the car the owner is having problems like knocking and flares. After I got the car I changed the fluid to Mobil 3309 and make the B4 cover upgrade , make the adaptation and most importantly added a trans cooler and a filter. Now after 100.000km it is still going strong.We will see how long it can last :)[/QUOTE]
With respect, the transmission probably wasn't broken. If you've done the above and driven 100k since, then the likely hood is the trans oil was heavily contaminated and not able to cool the box adequately. After 100k you definitely fixed the issue.
Post 821309 by azatoglu on 2021-05-06 07:07:27
I hope you are right :) thanks
