Auto Car - Volvo ramps up emissions targets with large-scale component reuse
Post 821428 by VPCUK on 2021-06-04 00:14:15
ImageAmbitious plan to cut costs and CO2 could also pave the way to second-life EV batteriesVolvo Cars is planning a 2.5 million-tonne reduction in its annual carbon emissions by reusing and remanufacturing components on a large scale. The process, which it calls a “circular business principle”, will include recycling key materials such as steel and aluminium, remanufacturing complex components like gearboxes and reconditioning individual parts. Volvo remanufactured some 40,000 parts last year, saving 3000 tonnes of CO2, and recycled 95% of its production waste (including 176,000 tonnes of steel) to save 640,000 tonnes of CO2. Volvo is also collaborating with battery reuse specialist Battery Loop to investigate the potential for a second life for high-voltage EV and hybrid batteries, all with the intention of becoming a ‘fully circular business’ – using entirely recycled parts – by 2040. Mechanical components included in the company’s reconditioning programme include brake calipers, electric rear axles, compressors, generators, suspension and chassis parts and EV traction motors, as well as engine blocks and cylinder heads. Anders Kärrberg, Volvo Cars’ head of strategy and sustainability, said: “There are major sustainability benefits of doing this. If you compare a new part with a remanufactured part, you save about 85% of the CO2. There are major benefits in terms of reducing consumption of the virgin material, too.” Image Kärrberg explained that parts such as calipers could be remanufactured three or four times, extending their life to 20 years before being superseded during the evolution of design. He said: “We’re on the track of doubling the consumption of metals and minerals in the next 40 years, and we’re generating more and more waste. This is simply not sustainable. It’s not just that we’re generating waste materials: we’re also generating a lot of CO2. “In order to reach the Paris Agreement and reduce CO2, we have to do more recycling and remanufacturing. This is why companies like Volvo are in for a fundamental change. “A circular economy will be important, but we do see a business opportunity in this and financial benefits in more efficient use of materials and remanufacturing. It’s good for the environment, but it’s good for business as well.” Giving high-voltage batteries a second life once their capacity has reduced too far through age and use for them to satisfactorily power an EV is widely regarded throughout the car industry as being a sound method of reducing the environmental impact of battery production. Volvo’s director of traction battery development, Ulrik Persson, believes doing so could extend the life of an EV battery to as much as two decades or even more. Pure EV batteries are worked hard through the aggressive cycling they undergo. He said: “Fast charging is an example of aggressive cycling, as is high-speed motorway driving, where you run the power through the battery system very quickly during charge and discharge.” Second-life applications can be far less aggressive, with much gentler demands being made on the batteries for stationary applications, such as grid balancing – the storing in batteries of surplus electricity that’s generated off peak, to be fed into the grid during peak periods at a battery-friendly rate. Using old EV batteries for grid balancing is a valuable addition to sustainable energy generation from wind turbines and solar panels, which may harvest large amounts of energy when demand is low. “Battery systems need to be dimensioned to each application,” said Persson. Image The battery capacity used in a particular application will determine how deep or shallow the cycling is. Too much is wasteful; too little will result in deep cycling. As long as the battery system isn’t deeply discharged, and instead just part of the available capacity is used, Persson believes the prospect for extended life is good. He said: “The design life for our battery systems is 15 years. I think the life of the battery could be extended for an additional five or maybe 10 years if the battery is used in the correct way. Time will tell and other factors will play a part. The battery degrades not only from cycling but also ageing and temperature.” Once batteries do reach the end of their life, the aim is to retrieve and recycle as many materials as possible. To achieve the circular economy, we must treat all ingoing materials as precious, and we’re participating in extensive research into hydrometallurgical extraction of the battery materials at Chalmers University in Gothenburg,” said Persson. READ MORE Volvo to downsize saloon and estate offering in SUV-led EV push  Analysis: Why Volvo EVs are online only  Volvo C40 Recharge electric coupé-SUV arrives with 402bhp More... Please note this is external content and not under the control of those that run this site.
