Post 821552 by Potato pete on 2021-07-11 20:24:09
Hi, I'm looking at swapping the rear 4c shocks on the v70r but I'm struggling to locate replacement rear mounts. Does the cast alloy fitting £150.00, contain the rubber bush or is the bush a separate item £54 (part 5 on Volvo diagram) which then slides into the alloy casting and is held in position by the cover plate? The dealer isn't much help so thanks for yours.
