Post 821856 by Sverre63 on 2022-01-07 03:22:28
Hello everyone I'm a Norwegian who lives in Thailand and got a Volvo 850 GLT and is now in the process of rebuilding my engine. My issue is or problem is...to find what main bearings I need....it is so confusing because I have found 3 markings on the engine that I have found is related to bearings. I found one marking at the top of the block, right-hand side at the crank side. One marking at the bottom of the block, right-hand side at the crank. And lastly a marking on the crank itself Top of the block marking: 1DDDDDD Bottom of the block marking: 1ABBBBB Marking on the crank: 1BBBBBB So can you guys tell me what bearings I need and where they belong....also if possible part numbers on the bearings. I will be greatly thankful for any help. Sincerly Sverre
