Removing rear trim panel on V70
Post 822893 by mrsey on 2024-08-19 12:34:14
I need to replace on the nearside rear indicator relay on my V70 (Phase 3, 2013) and I'm pertty sure it is behind the rear nearside internal side trim panel.. I can't see how to remove the trim panel. Does anyone know the steps for removing these? Thanks!
Post 822894 by MoleT-5R on 2024-08-20 10:42:27
If it's anything like the xc90, you need to life the boot floor panel and remove it's retaining straps and lift it out of the way. Then you should then be able to remove the floor corner section by lifting it up and out. The panel should then pivot out if I remember correctly......hope that helps.
