Post 67522 by Colin 850 T5 on 2005-12-24 00:02:15
Poking around the engine bay I discover a brass fitting inline on the hose to the wastegate. It has a spring and thread so it must adjust/restrict pressure to the waste gate.
Looking at Siamblues pics on the HID thread he has described a similar device as being an MBC Mk2 etc.
This brass item on mine is almost definitely not standard judging by the hoseclips used so am I looking at part of or all of an MBC?
Post 67534 by siamblue on 2005-12-24 03:09:13
Looks like it Colin put a pic up and we can tell you for sure,
Gary
Post 67538 by jross on 2005-12-24 07:41:06
[QUOTE=arbee]whats an mbc?[/QUOTE]
manual boost controller
allows you to manually set the boost level (instead of using the ECU to control boost)
Post 67614 by Unknown on 2005-12-24 20:38:41
[QUOTE=jross]manual boost controller
allows you to manually set the boost level (instead of using the ECU to control boost)[/QUOTE]
ahhh, ta :)
Post 74197 by LeeT5 on 2006-01-23 05:04:28
[QUOTE=Colin 850 T5]Poking around the engine bay I discover a brass fitting inline on the hose to the wastegate. It has a spring and thread so it must adjust/restrict pressure to the waste gate.
This brass item on mine is almost definitely not standard judging by the hoseclips used so am I looking at part of or all of an MBC?[/QUOTE]
Careful - this could also be a Bleed valve. If it is then out it. They are rubbish as weather affects them ie atmospheric pressure and air temp also, so performance will be good one day and better the next.
Do your research on these baby's cos there are many types. (Although cant remember if Bleed valves have a ball bearing and spring???) plenty of know how and advice here...
