Post 67532 by Vikingxl on 2005-12-24 01:00:34
While my car is off the road for a while i was thinking of cleaning up and painting the brake carriers and calipers anyone got any ideas on how to clean them up and what to paint them with?The carriers were new and shiny a few months ago but now look a bit nasty and as im hoping to fit my Titans in the new year it would be nice to get them looking good again.
Post 67533 by siamblue on 2005-12-24 03:06:18
Hi Mate, I used carb cleaner to clean mine off, then painted them with Hammerite Smooth,
Gary
Post 67545 by Vikingxl on 2005-12-24 09:22:26
Cheers Gary will give it a go i'm thinking of black anyone think another colour would be any good?
Post 67563 by t5owner on 2005-12-24 12:01:54
Cleaned mine up with a wire brush and power drill combo then used wilko aluminium paint @ 99p still looks good and no signs of rust as yet
Cheers
stuart
Post 67564 by Rufe on 2005-12-24 12:10:07
hammerite is also a good paint to use for these. most important thing is cleaning the surface up before hand though, hard wire brush and plenty of carb spray/brake cleaner will be sufficient. what ever you do though, do not go and buy a caliper painting kit though, they are usually about £20 or something i believe.... there are plenty of good hard wearing metal paints (such as hammerite, which i used) for a lot lot less. a small tin was plenty for all four of my wheels.
Post 67679 by Martinr on 2005-12-25 13:19:10
I used Halfrauds Caliper paint to do mine. £9 a tin but I have enough left to do the job 4 or 5 times more!
I brushed mine down then used meths to remove grease. No problems at all.
Mine are yellow which looks good on the black car. Also took the opportunity to paint the hub units of the rotors (not the face the wheel fits on to), did them black which looks nicer than the rust that they were :) Used engine paint to cope with temperature.
Post 67785 by Wobbly Dave on 2005-12-26 23:34:09
I can help you with it if you so wish
Post 67836 by Vikingxl on 2005-12-27 18:31:30
Cheers Wobbly thats another project for us then!
Post 70248 by t5tart on 2006-01-07 01:30:33
think ill be doing mine when i cahnge the shockers
Post 70273 by Vikingxl on 2006-01-07 09:41:47
If i remember i will take some piccys and do a how to guide while im doing this.
Post 70426 by t5tart on 2006-01-07 22:19:57
who used hammerite how is it holding up ???
Post 70446 by T5R+ on 2006-01-07 23:22:16
Hammerite (used both smooth & also "rough") - held up amazingly well (>3years).
Post 70504 by t5tart on 2006-01-08 01:44:46
excellent
good cheap readily available choice then
