C70 Problems with Roof
Post 72442 by JonK on 2006-01-16 13:17:43
Hi There I live in Dublin - Ireland and am [was] the proud owner of a C70 convertible. The roof is now giving me problems and wont close properly. The local dealer is saying that the sensors are out of sync - the being quoted to me costs to fix this are very high. Can anyone give me any advise as regards the best way to fix this. Do you know of any garages in Northern Ireland or Ireland who could fix this ? Thanks,
Post 72449 by fraz13 on 2006-01-16 13:38:11
I've read about this before, The sensors give up and from what I read was the roof needs removed which is where the high cost to repair comes from, Dont know if theres an easy fix but good luck....
Post 72678 by After_Shock on 2006-01-17 09:12:32
Theirs no easy fix, but its a rare fault.
Post 78420 by MartinK on 2006-02-06 17:45:20
Isn't there a manual windy-crank thing in the boot you can use? Have you tried fully opening the roof and then fully closing it with that? Maybe it'll reset things? (Of course, I've not tried using it on mine yet). I don't envy you the job, though. You'll be winding that little handle for hours. I guess you could attach an electric screwdriver with the right size allen-key bit. ;)
Post 78427 by madness on 2006-02-06 17:50:57
the handle takes about 45 minutes to use!!!!! it moves at the speed of next to nothing :frown:
Post 79299 by Babybadger on 2006-02-09 16:39:48
[QUOTE=madness]the handle takes about 45 minutes to use!!!!! it moves at the speed of next to nothing :frown:[/QUOTE] Use a drill!
