Tracs
Post 73314 by t5tart on 2006-01-19 15:59:44
whats needed and has anyone retro fitted the TRACS system wheelspin is killing me
Post 73316 by Mrsmopp on 2006-01-19 16:02:03
Tracs is a load of pants IMO! It never worked on any of my 850's x
Post 73318 by t5tart on 2006-01-19 16:04:36
oh right lol um thought it worked ????? ho hum maybe a little less right foot then lol
Post 73320 by mraldonnelly on 2006-01-19 16:10:05
STSC is less pants on the V70 (actually, it does seem to work well most of the time) but I usually drive round with it switched off. I guess it would be possible to retrofit TRACS as it works in conjunction with the ABS but I'd guess a software update would be required. Doubt it would be worth it though - just use a little less gas when pulling away. Regards Andy
Post 73323 by Mrsmopp on 2006-01-19 16:12:43
LOL - In all of the 850's I have had you have never been able to tell whether you have tracs switched on or off. Feed the power in....... x
Post 73332 by Wobbly Dave on 2006-01-19 16:22:22
If you want to fit traction control I suggest you go with a aftermarket solution. I saw the racelogic system on Redbrick's 855R and he said it works very well indeed.
