Fix for DIM/DIP! Switch off those lights once and for all! Easy!
Post 75931 by siamblue on 2006-01-29 16:30:31
Nice one Martin and Simon, It's great when you beat these little issues :)
Gary
Post 75932 by Tomcat on 2006-01-29 16:31:56
Can we have this put in the 'How To' section so its there for everybody to see. Well done that man!
Post 75973 by Andy on 2006-01-29 19:23:01
Cheers Pzorb...
What happens if you have a 1994 850 without the grub screw altogether?
Post 75975 by Andy on 2006-01-29 19:23:43
Cheers Pzorb!
What happens though if you have a 1994 850 without the grub screw?
I'd like my lights off during the day!!
Post 75979 by pzorb on 2006-01-29 19:33:23
Hmmn, I wouldn't like to say! The problem with mine was that somewhere between the switch and the lights a dim/dip relay was stepping in and powering the lights. Even without the switch plugged in, the lights would still be on.
I'd prise the switch out of the dash, and unplug it. Then see what the lights do when the car's electrics are started with the key. The pictures on this link might help.
http://www.vpcuk.org/forums/showthread.php?t=5040
If they stay off, then you're looking at new wiring at the switch end. You might get lucky and find that a newer switch sorts the problem. If they stay on, then it's somewhere else - maybe try the same trick with the relay pin... but I'd ask around to see if anyone else knows.
Good luck! Keep us posted too!
Post 75990 by LeeT5 on 2006-01-29 19:47:31
[QUOTE=Andy]Cheers Pzorb!
I'd like my lights off during the day!![/QUOTE]
get a new headlight switch for a late 850 ie '96 from main dealer (thats what i did) and problem solved. :)
Also this seemed to cure the daylight running lights problem! So for me i didnt need to muck about busting expensive relays. BTW get a price for a new relay b4 you mod cos you might think twice...they aint cheap :frown:
Post 75994 by Andy on 2006-01-29 19:57:06
[QUOTE=LeeT5]get a new headlight switch for a late 850 ie '96 from main dealer (thats what i did) and problem solved. :)
Also this seemed to cure the daylight running lights problem! So for me i didnt need to muck about busting expensive relays. BTW get a price for a new relay b4 you mod cos you might think twice...they aint cheap :frown:[/QUOTE]
Thanks mate, I will speak to salvo and see if they can send me one up.
Post 76071 by LeeT5 on 2006-01-30 00:57:38
[QUOTE=Andy]Thanks mate, I will speak to salvo and see if they can send me one up.[/QUOTE]
:B_thumb: no probs.
Post 76209 by t5tart on 2006-01-30 14:52:48
how much was the switch ?
Post 76240 by Vikingxl on 2006-01-30 15:32:51
Glad you finally got it sorted.
Post 76356 by LeeT5 on 2006-01-30 21:09:17
[QUOTE=t5tart]how much was the switch ?[/QUOTE]
Sorry no. But the figure of £30 something quid rings a bell.
Post 77304 by Andy on 2006-02-02 18:09:47
[QUOTE=LeeT5]Sorry no. But the figure of £30 something quid rings a bell.[/QUOTE]
Sounds about right through the likes of salvo etc.
Post 79214 by Andy on 2006-02-09 10:59:57
I done what Pzorb suggested this morning i.e. removed the headlight switch and started the car up.
I took the switch off with the headlight switch in 0. The only lights left on with the switch disconnected were the side lights in the main headlamp.
What does this mean then?
I checked the relay and mine is identical to the one in the pictures on this post.
I have ordered a 1996 switch with the grub screw to see if that turns the lights off (like lee suggested) but if this does not work then i think i might be inclined to snap the little leg off the relay (as long as i have a spare relay handy :))
Post 79217 by S60D5 on 2006-02-09 11:05:07
Andy when we going to get some pics of her then?
Post 79219 by Andy on 2006-02-09 11:09:29
[QUOTE=S60D5]Andy when we going to get some pics of her then?[/QUOTE]
I'll get some today mate. Been working but am off now so have no excuse.
I'll go wash her (even though its baltic cold) and get some pics :D
Post 79222 by S60D5 on 2006-02-09 11:11:48
[QUOTE=Andy]I'll get some today mate. Been working but am off now so have no excuse.
I'll go wash her (even though its baltic cold) and get some pics :D[/QUOTE]
Look forward to them mate!
Post 79226 by pzorb on 2006-02-09 11:25:22
[QUOTE=Andy]The only lights left on with the switch disconnected were the side lights in the main headlamp.
i think i might be inclined to snap the little leg off the relay[/QUOTE]
Sounds to me like the switch isn't fully in charge of the lights. Mine did the same without the switch plugged in, main beam stayed on. I hope the new switch sorts out your problem, or you'll have a new light switch with a novelty screw on it! Your car seems to be younger than when DIM/DIP regulation was breifly introduced; certainly if you have the additional module it's pin bending time. It's just so annyoing that for whatever reason Volvo have reworked the wiring at least three times in as many years!
Remember, you don't need to snap that pin off. Bending it offers you the chance to unbend it! Just be gentle.
Personally, I'd try bending the relay pin first before ordering the switch but hey you might break it off I guess and I'm assuming these aren't cheap. Disclaimer!
Keep us posted!
Post 79248 by Andy on 2006-02-09 12:31:57
The switch was only a tenner so i've scored on that one! :D
Post 79878 by Andy on 2006-02-11 18:23:57
Pzorb,
Just to keep you updated.
I got the new switch through the post this morning and tried it straight away the results were as follows:
The lights would stay on regardless when the switch was unplugged.
The only effect the grub screw would have is to turn the parking lights off.
Anyway the lights didn't turn off with the new switch so I got the needle nose pliers out.
56B pin was bent in and VOILA!!! Sorted! :D Very Happy.
Thank you for the help.
Post 79976 by LeeT5 on 2006-02-12 01:12:35
[QUOTE=Andy]Pzorb,
Thank you for the help.[/QUOTE]
:) Worth a shot though. (switch)
Post 80067 by Andy on 2006-02-12 16:11:59
[QUOTE=LeeT5]:) Worth a shot though. (switch)[/QUOTE]
Oh deffo :D
Post 80767 by V70Man on 2006-02-15 15:55:49
A coupple of questions:
1: I have a 2000 V70, and there doesn't appear to be any difference in brightness between position 1 and 3, only 2 is different as this is the parking lights. Is it just me?
2: Could insurance companies get a bit funny in the event of a crash if I modify my car to turn the lights off during the day? I know it may sound picky but I know what some companies can be like.
Thanks.
Post 80817 by Andy on 2006-02-15 18:16:27
[QUOTE=V70Man]A coupple of questions:
Thanks.[/QUOTE]
If I remember correctly position 1 is lights off? Number 3 is lights on and number 2 is parking lights only.
The reason your lights are the same in position 1 is because they have been set to come on automatically (even though there in the off position).
Insurance companies may get a bit picky, but seen as the lights off job on a V70 2001 can only be done at the dealers who's to say they done that by accident, if you know what i mean ;)
Besides the insurance company couldn't tell if you turned the lights off anyway. Just plead ignorance.
Post 85729 by Ian.S on 2006-03-03 15:40:21
Excellent mod, just the ticket, tyvm :B_thumb:
Post 172199 by markbolts on 2008-08-04 12:48:11
just got my 1st t5 sat,and have sucessfully modded the grandad lights!!!thanks a bunch guys!!!will be addin pics soon so lookout!
Post 172232 by Rufe on 2008-08-04 14:51:01
i personaly wouldnt worry about the insurance company... insurance companies cant force you to drive with lights on in the day
early cars had the tiny switch on the headlamp switch so you could decide if you wanted day runners or not, later cars have an option that the dealer can turn them off, for a cost of course, and doing that wouldnt invalidate any insurance. Ignornace is bliss though as they say, so if you are worried, then say the car came like that.
