New Discs and Pads - Now spongy pedal
Post 78307 by rgracin on 2006-02-06 13:02:04
Just replaced the discs and pads on my p2 V70 T5. I have put Brembo replacement discs with Ferrodo DS2500 pads. Before, the brakes felt great with a high pedal. Now, they feel spongy. I can't see how any air got into the system. Any clues as to what might be the cause??
Post 78308 by fireclown on 2006-02-06 13:05:33
hi new discs and pads will feel spongy until they are beeded in proply. take it for a steady run and apply the brakes gently. they will firm up.
Post 78314 by Goof on 2006-02-06 13:25:12
You'll need to get some heat into them to help "cure" the pads - but don't go too mad, don't try to fry them too soon! You may also experience from the gasses released during the curing process a feeling of sponginess and faded performance as the gas is escaping between the new pad and disk. Bedding in new pads can be far more complex than just wearing off the rough bits so they fit the disk.
Post 78325 by rgracin on 2006-02-06 14:25:02
I presume that with the harder pads, this proccess will take longer?
Post 78339 by Goof on 2006-02-06 14:48:19
Probably. Proper bedding in of new pads *can* help performance, wear rate and reduce brake squeal. I'm not normally this techie on a subject - I have minor brake issues atm on my m/cycle, so typically I've Googled loads recently!
Post 78342 by t5tart on 2006-02-06 14:52:40
[QUOTE=Goof]Probably. Proper bedding in of new pads *can* help performance, wear rate and reduce brake squeal. I'm not normally this techie on a subject - I have minor brake issues atm on my m/cycle, so typically I've Googled loads recently![/QUOTE] best way to bed them in is to get to about 70 on a long straight road break hardis down to about 30 DONT STOP do this about 6-7 times then drive for a couple of miles to cool off the brakes before parking up then let them cool right off for afew hours then repeat the process all over again but being a biker you would know this from beding in bike brakes its a matter of tempering the discs
Post 78350 by Goof on 2006-02-06 15:02:36
[QUOTE=t5tart]best way to bed them in is to get to about 70 on a long straight road break hardis down to about 30 DONT STOP do this about 6-7 times then drive for a couple of miles to cool off the brakes before parking up then let them cool right off for afew hours then repeat the process all over again but being a biker you would know this from beding in bike brakes its a matter of tempering the discs[/QUOTE] Sounds like a normal run out for me - of course, I never get the bike above 70 anyway... ;) For those that are wondering why "Don't Stop" was in caps - stopping after that sort of use *can* lead to disk warp. Similar to during a track day run - don't do several fast laps and pull into the pits and apply the handbrake as this has been known to cause disk warp, they need to be cooled without the pressure of a handbrake gripping a hot disk! And, don't be tempted to touch them - they can reach 450+C easily ~ fingerprint stripping stuff! (Ok, who hasn't done it?...).
Post 78374 by t5tart on 2006-02-06 16:10:04
doesnt even need to have the handbrake applied the close prosimity of th epad to the disk on that section means it cools slower than the rest causing a warp sometimes i know i have done it to brakes in the past should really let the brakes cool after and use for a couple of miles b4 parking up anyway....... espoecially if say a dog has run out in front of you and you have had to use them hard...cause of corse no one would be going fast enuff to use them hard on pubilc roads unless it was an emergency
Post 78381 by GATHY on 2006-02-06 16:17:57
[QUOTE=rgracin]Just replaced the discs and pads on my p2 V70 T5. I have put Brembo replacement discs with Ferrodo DS2500 pads. Before, the brakes felt great with a high pedal. Now, they feel spongy. I can't see how any air got into the system. Any clues as to what might be the cause??[/QUOTE] silly question but you have check you fluid level as when youve push your piston back all the way then fitted the new pad/disks and pumped the pedal back the fluid level drops again ? (
Post 78630 by rgracin on 2006-02-07 08:41:31
Fluid level is fine. In fact, I had to drain some off.
Post 78633 by mraldonnelly on 2006-02-07 08:57:15
Did you flush the system? If not it would be worthwhile doing anyway. If any air did get into the system a flush should remove this and you'll also benefit from new fluid too. Regards Andy
Post 78921 by rgracin on 2006-02-08 08:11:20
System is being flushed today in fact. I'll let you know how it all feels. Going to be doing a few miles in it next week which should help the bedding in process.
Post 79233 by mraldonnelly on 2006-02-09 11:44:24
[QUOTE=rgracin]System is being flushed today in fact. I'll let you know how it all feels. Going to be doing a few miles in it next week which should help the bedding in process.[/QUOTE] Did you get the fluid changed yesterday? If so, how's she feeling now? Regards Andy
Post 79244 by pyrotechnictigger on 2006-02-09 12:23:21
Had exactly the same problem after doing mine. Spongy feel and I hate it! Had the fluid flushed and done with dot5. Not really done much, sniff :slap:
Post 79261 by rgracin on 2006-02-09 13:47:15
Haven't driven it yet, New windscreen came, and was too small. but tha's another story. Now need to wear goggles!!. Closer inspection of the discs shows that they are only braking on two thirds at the moment, so I'm pretty sure they just need bedding in. Have only done about 50 miles since changing them. So only time till tell. :slap:
Post 79264 by mraldonnelly on 2006-02-09 14:20:19
[QUOTE=rgracin]Haven't driven it yet, New windscreen came, and was too small. but tha's another story. Now need to wear goggles!!. Closer inspection of the discs shows that they are only braking on two thirds at the moment, so I'm pretty sure they just need bedding in. Have only done about 50 miles since changing them. So only time till tell. :slap:[/QUOTE] Did you replace them yourself? Are you sure the discs are seated straight? They should really be braking around the full diameter of the disc from the start. It sounds to me as though either the discs are bent / warped or they're not seated correctly, perhaps as a result of dirt on the hub mating face or something. Did you torque the wheel nuts up correctly? Regards Andy
Post 79281 by Babybadger on 2006-02-09 15:37:34
[QUOTE=Goof]You'll need to get some heat into them to help "cure" the pads - but don't go too mad, don't try to fry them too soon! You may also experience from the gasses released during the curing process a feeling of sponginess and faded performance as the gas is escaping between the new pad and disk. Bedding in new pads can be far more complex than just wearing off the rough bits so they fit the disk.[/QUOTE] That gas will have a smell and that smell will be the fish smell then.......or was that the cat and the kipper on the front wheel.....
Post 79429 by Goof on 2006-02-09 23:06:57
[QUOTE=Babybadger]That gas will have a smell and that smell will be the fish smell then.......or was that the cat and the kipper on the front wheel.....[/QUOTE] No! - all true I believe mate! - well, from what I've read elsewhere anyway. :)
Post 79466 by rgracin on 2006-02-10 08:15:02
[QUOTE=mraldonnelly]Did you replace them yourself? Are you sure the discs are seated straight? They should really be braking around the full diameter of the disc from the start. It sounds to me as though either the discs are bent / warped or they're not seated correctly, perhaps as a result of dirt on the hub mating face or something. Did you torque the wheel nuts up correctly? Regards Andy[/QUOTE] I did do them myself. All surfaces were free from foreign bodies, and smeared with copper grease. I think you may have misunderstood. The surface which already shows signs of wear if you like is three quarters of the disc from the outside towards the centre. Warping or incorrect seating would show via 'on off' wear around the disc. Window should be back in today so I can get her back and let you know how it goes. BTW, what is the correct torque setting for the wheel bolts. I've always gone by feel in the past, but I now have a shiny new torque wrench ready to go!
Post 79768 by mraldonnelly on 2006-02-11 10:27:34
Ahhhhh, gotcha. Phew, I thought you meant around the diameter of the disc. IIRC the torque setting is 110 something but I can't remember if it's nm or ft lb's without checking my Haynes manual. I'll have a look later and post it up if someone hasn't already done so. Regards Andy
Post 80049 by racer on 2006-02-12 15:00:19
Spot on with the number Andy, road wheel bolt torque setting is 110nm or 81 ft lb.
Post 81258 by rgracin on 2006-02-17 08:14:00
Right, New windscreen now in...at last. After a broken wiper arm as well. A massive thanks to the chaps and the Volvo main agent in Reading (think they are Stratsone) for sending a new one overnight last Friday. Made the trip to Wales a little easier with a drivers side wiper!! Anyway, did a few hundred miles this week, and the pedal seems to be almost back to normal. Not quite there yet, but noticebly better than before.
