Moded (moded grill)
Post 81634 by stuAWD on 2006-02-18 18:56:48
3 coats of primer, 3 coats black paint, four coats of laquer on a standard V70 grill. Bloody road gritter polka dotted it last night on M61. Its gonna have to be done again B*****d.
Post 81635 by Vikingxl on 2006-02-18 18:59:22
Unlucky mate!
Post 81660 by iGGy on 2006-02-18 20:21:23
I know the feeling :mad: This time I've invested in a can of Plasti-dip and that should hopefully stop any chipping.
Post 81834 by RPM on 2006-02-19 17:17:14
have you modded a standard grille? any pics?
Post 82144 by stuAWD on 2006-02-20 15:01:51
[QUOTE=RPM]have you modded a standard grille? any pics?[/QUOTE] Indeed I have. To match the wheels and mud flaps.
Post 82151 by iGGy on 2006-02-20 15:35:11
Here's mine using the original grill: Image I'm thinking of having the wheels redone darker when they are refurbished.
Post 82153 by Waxworks on 2006-02-20 15:43:05
and heres mine, does suffer from stones chips but just i touch them in every six months. Sometimes it's better not to put too much paint on as stone chips can look worse/deeper.
Post 82154 by The Flying Banana on 2006-02-20 15:47:33
TWo stunning looking cars, re getting the wheels darker on the 850R...the car looks fantastic the way it is .....dark on dark does look stealthy but the way it sits just now fab!! Oh no i can feel a change of colour for my wheels coming on now !!! :slap:
Post 82155 by RPM on 2006-02-20 16:02:57
is there a how to on the way you guys did your grille?
Post 82227 by stuAWD on 2006-02-20 19:52:26
[QUOTE=RPM]is there a how to on the way you guys did your grille?[/QUOTE] There is somewhere, But here we go again: - Lift your bonnet, slide out the 5 clips at the rear of the grill, grill should push out. Then with a spiky thing carefully prise off the the four spring clips holding the Volvo name badge on, try to be gentle, and you will find you can reuse the clips (save you a trip the ironmongers). There is a rubber seal round the outer edge of the grill, if you want to remove this you can, but you will have to use some sort of adhesive or double sided tape to replace it (I left mine in situ and taped over it with some thin lining masking tape). Next comes the tedious bit, check for any imperfections in the grill if there are any which is unlikely, fill them with body filler. Then rub the whole thing down front, back, and between the ribs using fine wet & dry emery.(tedious but worth it). Using spray paint suitable for plastic surfaces, primer 2 coats minimum, colour coat 2 coats minimum, & then laquer 2 coats minimum. Leave to dry and cure overnight, refit. The four spring clips that hold the name-plate on, turn them flat side down on flat surface and flatten the centres back into position before refitting them. After my gritter episode I used Hammerite stone chip shield, the grill is drying as write this, will let you know the result. Have posted this on the how to.
Post 82275 by RPM on 2006-02-20 21:41:33
thanks, might just go buy a 2nd hand grille to play with!!
Post 82276 by Vikingxl on 2006-02-20 21:44:26
[QUOTE=RPM]thanks, might just go buy a 2nd hand grille to play with!![/QUOTE] Rpm i have one without the badge that you are welcome to if you want it i can bring it at the weekend if you want!
Post 82303 by RPM on 2006-02-20 22:22:48
for free?
Post 82304 by Vikingxl on 2006-02-20 22:24:00
[QUOTE=RPM]for free?[/QUOTE] Yeah free to a good home let me know if you want it and i will dig it out!
Post 82307 by RPM on 2006-02-20 22:28:47
yes please
Post 82309 by Vikingxl on 2006-02-20 22:31:54
Thinking about it it wont fit on your car as its off a v70 but you are still welcome to it so that you have something to practice on as all its doing is getting in the way here.I will stick it in the car tomorrow so i dont forget it at the weekend!
Post 82310 by RPM on 2006-02-20 22:34:41
i'd better not then if it won't fit............. RG will only get grumpy if the spare parts pile builds up gaian. Especially if they are for a different car.........hahaha
Post 82311 by Vikingxl on 2006-02-20 22:36:41
Up to you mate it will be in the car anyway so if you want it have it at least you could have a go and if it works then do the same to yours and throw this one out.
Post 82919 by gazjacko on 2006-02-22 23:56:48
All this talk has spurred me on to resurect my satin black painted grill from the garage. I too did the primer/primer/top-coat/top-coat/top-coat GRITTER!!! routine and ended up with an acned nose! I've decided to try for getting it sand-blasted to remove the old paint and give a good key to the new then have a really good think about what one to use. head of the queue so far is plastic primer then Black Satin Hammerite :B_steerin
Post 82951 by The Flying Banana on 2006-02-23 08:58:57
I got mine shot blasted at the same smae as the wheels, couldnt powder coat cos its plastic ( albeit fecking hard plastic) and it would have melted in the heat. But after being blasted it was a doddle to get primed, painted and laquered and baked in paint oven, bit of plasticiser in paint and no more chips!!
Post 83375 by stuAWD on 2006-02-24 15:28:33
[QUOTE=The Flying Banana]I got mine shot blasted at the same smae as the wheels, couldnt powder coat cos its plastic ( albeit fecking hard plastic) and it would have melted in the heat. But after being blasted it was a doddle to get primed, painted and laquered and baked in paint oven, bit of plasticiser in paint and no more chips!![/QUOTE] Top one. Just repaired mine using the Hammerite stone chip guard, holding up at the moment, but the gritters aint got me so far, tempted to go lookin for them to give it the ultimate test. :haha:
Post 83384 by M44K TS on 2006-02-24 17:05:49
that's i dentical to what i did to mine last summer Iggy, looked alright aswell, but now i have standard and want to go back :lol:
Post 83407 by stuAWD on 2006-02-24 19:04:54
[QUOTE=T5Mark]that's i dentical to what i did to mine last summer Iggy, looked alright aswell, but now i have standard and want to go back :lol:[/QUOTE] Did the Hammerite stand the test of time.
