Post 82915 by bigbad on 2006-02-22 23:48:55
hi i could do with some of your knowledge chaps, 1999 t5 58,000 mls fsh seams to use 1 pint of oil to 700 mls i have also put in 1/4 cup of water ! the oil that i top up with is optima 10/40 semi .(cheap crap ?)
she has no leaks , dont smoke etc, no oil in the water , the dipstick and oil filler cap are both ok ! do these cars do head gaskets , or have known problems ? . She runs great , so any idears ?
simon
Post 82918 by craig on 2006-02-22 23:55:53
mine uses oil too ,no leaks or smoke and head gasket is fine just keep topping it up and dont worry about it .
Post 82927 by bigbad on 2006-02-23 00:15:21
does yours use 1 pint to 700 mls ? but i do like your reply ,
thanks
simon
Post 82935 by siamblue on 2006-02-23 02:14:16
Mine uses about the same, think, they all do, Gary.
Post 82949 by Vikingxl on 2006-02-23 08:56:05
Mines about the same as well i wouldnt worry about it too much just remember to keep checking it!
Post 82956 by t5tart on 2006-02-23 09:11:44
when it gets to 2 ltrs on 1000 miles like mine and u have blue smoke start to worry
might be worth checking the crankcase breather system though
Post 83647 by bigbad on 2006-02-25 16:24:17
thanks im feeling a bit bit happier now .
simon
Post 83648 by t5tart on 2006-02-25 16:28:32
if u got no smoke.. got no leaks
then its probably just normal useage
Post 83651 by fireclown on 2006-02-25 16:41:56
try doing a fresh oil change. then keep youe eye on it. when it gets a few miles on the oil , it does tend to use it.
Post 83652 by T5R+ on 2006-02-25 16:49:16
Do not worry too much ---->top-up and keep checking regularly.
Mine did similar a couple of winters ago (approx 1l per 1K miles) , since then all is as expected.
Winter time and short journeys are also sometimes accompanied by "mayonnaise" on the dipstick, but not filler cap, again do not worry.
Post 83847 by bigbad on 2006-02-26 13:12:10
60,000 ml service on wednesday , so fresh oil = fresh start !
also this site is great , . ilike my rallying and am stuck in a time warp late 70s to early 80s , with vauxhall chevettes , and boy do i find it hard to get parts and info for an hsr chevette , so much so that i have had to start making parts !!, so finding this site for volvos , was like fresh air ,!
thanks once again.
Simon
Post 83850 by Engineer on 2006-02-26 13:31:59
[QUOTE=bigbad]60,000 ml service on wednesday , so fresh oil = fresh start !
thanks once again.
Simon[/QUOTE]Keep your oil level inbetween min - max, it allows for expansion hence less oil consumption assuming engine in good nick. Mines just clocked 7000 mls since last oil change and only required half a pint of semi-synthetic 10W/40 at 6000 mls. Changing it this week for Redline.
