reset code required
Post 86521 by craig on 2006-03-05 21:11:30
just a quick one anyone, i took out my air filter today to clean it and unplugged the elctrical cable from the bcs, and then forgot to reconnect it and when i started it it cut out and the engine light came on .i remembered what i had done reconnected it the engine started ok but the light stayed on so i simply need the sequence to turn it off , (if you were wondering its the light with a triangle in it and an upside down y inside that)thanks .craig.
Post 86537 by t5tart on 2006-03-05 21:38:10
if u have the fly lead type its in the haynes manual i have typed the sequence out somewhere cant remember the thread now
Post 86539 by t5tart on 2006-03-05 21:38:55
found it http://www.vpcuk.org/forums/showthread.php?t=7554&highlight=fly+lead
Post 86592 by craig on 2006-03-05 22:36:28
:) thanks mate il sort it out at first light ,i,o,u,1.
Post 86657 by Jod T5 on 2006-03-06 07:05:21
you could always try the disconnect the battery method, i did a similar thing with the maf sensor. i disconnected the battery earth for four hours and it resets itself....it may leave a code in the system? but thats for another day....
Post 86686 by pzorb on 2006-03-06 11:38:03
Just to add that removing the battery *doesn't* fix the problem on certain models; my 1996 won't have any of it. Reset the codes, live with the light, or hope it sorts itself out.
Post 86699 by Jod T5 on 2006-03-06 12:51:03
[QUOTE=pzorb] my 1996 won't have any of it.QUOTE] :haha:
Post 86800 by craig on 2006-03-06 18:00:08
thanks guys, i read the faults and it was 121 ,as expected.but by following the instructions to the letter to reset it when i press the button for about 5 seconds nothing happens at all ,no light of any sort .? does mine need a different sequence for reseting as its a 94 m reg .maybe ADAM will know as he reset it last time i was there ,thanks in advance CRAIG...
Post 86826 by t5tart on 2006-03-06 18:40:15
I have a 94 m reg too and that sequence works for me hold the button in longer about 10 seconds..they can be tempramental
