top speed of a t4
Post 86904 by markt4 on 2006-03-06 21:22:36
any1 know what the supposed top speed is for a t4...been told its a 147mph..but that has to be wrong??? or i have problems
Post 86907 by madness on 2006-03-06 21:28:18
it is 147/143 auto in the book. im not saying how fast ive been but its more than that WITHOUT nos major factor- it needs a long run up . above 130 its pretty gradual
Post 86918 by Titch on 2006-03-06 22:06:17
Not to suggest for one minute that i have tried it but mine has also been faster than the manufacturers suggested top speed, i will say no more than that. having said that ,that was after i had avisit from simon from upsolute. not sure how accurate my speedo was at that speed though.
Post 86921 by t5tart on 2006-03-06 22:26:49
thats where a road angel is great gps speedo and imho on private closed safe roads at 140 my speedo is spot on to the gps..... so pretty accurate
Post 86962 by siamblue on 2006-03-07 00:14:34
[QUOTE=t5tart]thats where a road angel is great gps speedo and imho on private closed safe roads at 140 my speedo is spot on to the gps..... so pretty accurate[/QUOTE] my reads 1 mph lower at 120 kph lol, compared to the Origin B2. Gary,
Post 86977 by markt4 on 2006-03-07 07:32:32
just in my dreams i have it wont go over 135...but ill have to see if i can imagine a longer road in my next dream
Post 87346 by markt4 on 2006-03-07 21:59:29
been on to a bloke called simon at upsolute and the price has dropped to £295 and he can fit me in within 2 weeks....decisions..decisions...it is a extra 36 ponies
Post 87403 by JUDGENINJA on 2006-03-07 23:22:03
You only Live ( dream ) once :) :) :) .... He'll probably check your cr over at the same time to see if there are any underlying problems...
Post 87443 by mavv on 2006-03-08 02:14:06
i've never tried a top speed run in mine (yet)
Post 87607 by Ross9 on 2006-03-08 16:42:04
Get some mods on it ;) Jacqs did 0-150mph in 1.2 miles from a standing start, and was still accelerating as it went through the speed trap (speedo was reading around 155mph), the terminal after 400metres on the same run was 98mph, so there wasnt much gradual about it in the following 0.95 miles as it picked up 52mph. MTE remap, cone filter and full exhaust system (260bhp, 305 lb/ft) So, it's worth getting the mods. As it was when Jacq got it before she added any modifications it was capable of 145+ indicated and didnt require miles and miles to do that. Ross
Post 87825 by Enigma666 on 2006-03-09 00:36:07
I'd agree with Ross on that one. I've done 145+ and really doesnt take long to get there. That was standard at the time too
Post 87853 by madness on 2006-03-09 09:04:18
mark from experience lack of top end = boost/vacuum leak! when i had a bleed valve it took the top end off , and i also when i had a leak
Post 87862 by markt4 on 2006-03-09 09:28:35
cheers madness...how do i check for leaks...r they big pipes or little pipes??lol i havent got a clue...any 1 got any pics of the pipes i need to check?
Post 87874 by madness on 2006-03-09 09:53:03
follow pipes from turbo back , are they loose? look around the inlet manifold as well for obvious signs. if not, get someone to check it by pressuring the system this is the same principle as a bleed valve - better acceleration but no top end. only other thing i can think of, we had a t4 police car that wouldnt get to the top end, we had it on a loaded dyno and the wastegate was giving up under engine load but i think that was well before 130. and it lost power when it happened
Post 87878 by timway on 2006-03-09 10:07:06
Hello, :wave23d: I bought a T4 a few months ago, I've seen an indicated speed of 157mph, probably a true 151-153mph. (On a private airfield of course) :) I thought it must have already been chipped, but hooked up a boost gauge and it was peaking at just under one bar, so probably standard. It did take a few miles to get to that speed though (it was a very long private airfield) :lol: I'm getting an MTE ecu upgrade this weekend so hopefully the speedo will go off the scale, lol Probably worth finding out if somethings wrong before you get any upgrades done.... have you tried measuring the acceleration? Tim
Post 87885 by madness on 2006-03-09 10:20:01
gearing is against much over 160. you run out of revs as well . its just a case of how quick you get there.
Post 87892 by timway on 2006-03-09 10:38:13
True, it was doing over 6000rpm at that speed which is well past the peak power. I'm surprised it went as fast as it did to be honest, maybe I had a tailwind :)
Post 88107 by madness on 2006-03-09 22:41:40
i have no power peak. holds until i back off throttle- >> get yourself nitrous!!!!!!
