Post 87012 by stuAWD on 2006-03-07 10:42:09
MOT Monday, car went through no probs. Tester noticed a slight clicking noise on the steering at full left & right lock, hardly noticable with engine running. No noticable play in the steeing rack or any of the steering components or suspension. Has anyone experienced similar symptoms.
By the way the tester really did try to find something wrong with steering after hearing the clicking.
Post 87045 by Babybadger on 2006-03-07 12:43:40
Might be the bearing at the bottom of the steering column although this normally squeaks, but who knows.
http://www.volvospeed.com/Repair/70steering.php
Check that as well , also check the bump stops are greased as they will start making a sound soon as the grease wears off. This sounds probable at lock to lock
Post 87066 by t5tart on 2006-03-07 13:56:47
what kind of grease do you use on the bump stops??
Post 87223 by stuAWD on 2006-03-07 19:32:32
Cheers babybadger, will check that out, but the clicking noise is more of a metallic sound than a plastic type squeak.
If I cant find what it is, I can live with it until, like my mechanic says "let it delvelop".
Post 87246 by Engineer on 2006-03-07 20:04:14
[QUOTE=stuAWD]Cheers babybadger, will check that out, but the clicking noise is more of a metallic sound than a plastic type squeak.
If I cant find what it is, I can live with it until, like my mechanic says "let it delvelop".[/QUOTE]My money's on babybadger, high melting point grease for lock stops.
