Post 88306 by r07s on 2006-03-10 14:36:19
Howdo, Anybody had the above symtom? My driverside has stopped working - have changed bulbs and checked all visible wiring for damage etc... :worried: Wondered if anybody else had experienced this? chrs
[QUOTE=r07s]Howdo, Anybody had the above symtom? My driverside has stopped working - have changed bulbs and checked all visible wiring for damage etc... :worried: Wondered if anybody else had experienced this? chrs[/QUOTE] Same experience, but it happened that the new bulb was a dud as well as the old one. Maybe bad seating in the bulb hoder/bad connection. If you got a multimeter do a continuity test on the circuit, although this dont always give you the fault your after, but it is a start. :B_steerin
[QUOTE=r07s]Howdo, Anybody had the above symtom? My driverside has stopped working - have changed bulbs and checked all visible wiring for damage etc... :worried: Wondered if anybody else had experienced this? chrs[/QUOTE] If the light works on the other side then it is not the switch and not fuse. U need a power probe to power up the circuit and check continuity. Has to be a loose connection somewhere, speak to a volvo technician at the main stealer. Not come across it my self, sorry.
Does the bulb failure warning light up? May be a fault with the failure warning unit, i think the feed goes to it and then a separate feed out to each brake light. On my saloon its under the trim on the rear panel.
Im not convinced i have problem anymore! I was behind an 850 for a bit yesterday and realised that the brake light is the top red light!! :wtf: I drove into halfords yesterday cos my bulb failure light had started coming on when braking - didnt know what side it was so asked captain cock from halford to come outside and tell me. The light cluster i looked at has 3 bulbs, the middle being reverse the other 2 i now presume are tail/fog lights!! I reckon if i check the top buld it'll be knackered :slap:! Well thats what im hoping anyhow... Got to watch the Barain Qualifying first though :B_thumb: Thanks for the posts of advice guys - always appreciated!
