Post 8493 by Giles on 2005-03-11 15:59:41
Any ideas of where I start on this? Do you need to tee into existing pipes or what? Searched through site, but gave up after 2 mins!
you can either T off the pipe to the standard gauge (believe its a white pipe under the dash) or run a new pipe from the vac tree (next to the throttle body)
[QUOTE=Pedro Fandango]you can either T off the pipe to the standard gauge (believe its a white pipe under the dash) or run a new pipe from the vac tree (next to the throttle body)[/QUOTE] ? to any spare/blanked-off holes? Forgive me for being lame.
I have found it under the old forum on VT5 - I knew we had it somewhere This could do with transferring - if one of the moderators could oblige http://volvot5.proboards13.com/index.cgi?board=tips&action=display&num=1088163286
[QUOTE=dave850R]I have found it under the old forum on VT5 - I knew we had it somewhere This could do with transferring - if one of the moderators could oblige http://volvot5.proboards13.com/index.cgi?board=tips&action=display&num=1088163286[/QUOTE] great! cannot view it? closed?
If you cannot view the old forum I have changed my profile on it - so you can read it username = dave850R password = volvo
