Numpty question but whats the difference between a 2.4T and a T5???
Post 89624 by Tallpointy on 2006-03-15 15:16:21
:help: Having just had my 850 T5 written off by a LHD lorry on the M25 I'm now on the hunt for a new motah. I like the look of the V70 phase 2 estates but (and now here's the embarasing bit...) What is the diference between a V70 2.4T and a V70 T5 2.4 ??? I have tried searching the site but all I can see is that for some reason you cannot RICA a 2.4T up to the same power as the T5. Is there a mod that can be done to the 2.4T to get it going properly? Can anyone help? Ta, Darryn
Post 89626 by fraz13 on 2006-03-15 15:32:14
The T5 engine is 2.3 high pressure Turbo unless its a new T5 and then its 2.5 high pressure Turbo 2.4T is a low pressure Turbo
Post 89629 by Wobbly Dave on 2006-03-15 15:38:09
On the phase 2 cars, there is no such engine as the 2.4T as far as I know?? There is a 2.5T (with a low pressure turbo). The 2.4 is normally aspirated. The T5 engine is a 2.4 in capacity but would be branded as a T5 engine. Lifted off Volvo site - all engines combinations for the V70 phase 2... 70 2.0T (180 hp) [list] [*]Sporty five-cylinder 2.0 litre turbocharged petrol engine [*]240 Nm torque [*]0 to 100 km/h in 9.0 seconds [*]Variable valve timing [*]Cleaner emissions [*]Available with five-speed manual gearbox or five-speed automatic transmission [/list]V70 2.4 (140 hp) V70 2.4 (170 hp) [list] [*]Five-cylinder 2.4 litre engine [*]Superior fuel economy [*]Continuously variable valve timing [*]Advanced emission control [*]Available with five-speed manual or five-speed automatic transmission [/list]V70 2.5T (210 hp) V70 2.5T AWD (210 hp) [list] [*]Five-cylinder 2.5 litre engine with light-pressure turbo [*]320 Nm torque from just 1500 revs [*]0 to 100 km/h in 7.4 seconds (2.5T) or 7.6 seconds (2.5T AWD) [*]Dual continuously variable valve timing [*]Available with five-speed manual gearbox or five-speed Geartronic automatic transmission [/list]V70 T5 (260 hp) [list] [*]Highly efficient 2.4 litre turbocharged petrol engine [*]350 Nm torque [*]0 to 100 km/h in 6.8 seconds [*]Continuously variable valve timing for both inlet and exhaust valves [*]Available with six-speed manual gearbox or five-speed Geartronic automatic transmission [/list]V70 R (300 hp) [list] [*]Five-cylinder turbocharged petrol engine [*]0 to 100 km/h in 5.7 seconds [*]400 Nm torque from just 1950 revs (manual) [*]Double overhead camshafts, 20 valves [*]Dual Intercoolers [*]Three-way catalytic converter with Lambda sensor. [/list]Diesel V70 2.4D (126 hp) V70 2.4D (163 hp) V70 D5 (185 hp) V70 D5 AWD (185 hp) [list] [*]All-aluminium five-cylinder turbo diesel engine [*]High torque provides remarkable flexibility [*]Quick and comfortable response [*]Superior fuel economy [*]Cleaner exhaust emissions [*]Maintenance-free particle filter (D5) [/list]Bi-Fuel V70 BI-FUEL METHANE (CNG)/PETROL (140 hp) [list] [*]Five-cylinder 2.4 litre engine [*]Low emissions [*]Running costs extremely low [*]Advanced emission control [*]Available with five-speed manual gearbox or five-speed automatic transmission [/list]Source... http://www.volvocars.com/models/v70/techSpec.htm
Post 89632 by Wobbly Dave on 2006-03-15 15:44:24
[QUOTE=fraz13]The T5 engine is 2.3 high pressure Turbo unless its a new T5 and then its 2.5 high pressure Turbo 2.4T is a low pressure Turbo[/QUOTE] T5 is 2319cc only on the older cars - 850 and 70 series (phase 1)
Post 89634 by Wobbly Dave on 2006-03-15 15:49:57
Download the V70 Phase 2 Tech spec from Volvo UK... http://www.volvocars.co.uk/NR/rdonlyres/14F3CC61-BE9A-4596-BCBE-B2132547C587/0/UKMY06DecV70.pdf
Post 89635 by fraz13 on 2006-03-15 15:52:21
[QUOTE=Wobbly Dave]T5 is 2319cc only on the older cars - 850 and 70 series (phase 1)[/QUOTE] Thats what a said :haha: unless its a new one!!
Post 89639 by Unknown on 2006-03-15 16:09:04
[QUOTE=Wobbly Dave]T5 is 2319cc only on the older cars - 850 and 70 series (phase 1)[/QUOTE] My 2001 S60 T5 is 2319cc also.
