Obd2 - Usb
Post 91165 by S70T5 on 2006-03-21 15:15:53
Does anyone have any experience of using the OBD2 - USB interface's you can buy? I would like to get one to remove the SRS error code and turn off my SRS light off. :) Chris
Post 91201 by Justin on 2006-03-21 16:57:09
I have one, it works fine :)
Post 91208 by Unknown on 2006-03-21 17:04:35
[QUOTE=Justin]I have one, it works fine :)[/QUOTE] Justin - which software do you use ?
Post 91237 by S70T5 on 2006-03-21 18:16:00
Thanks Justin, would the type you have remove the SRS fault codes? Chris
Post 91240 by Justin on 2006-03-21 18:20:25
Not sure if it does SRS, should do, it reads all codes from the ecu. I'll check tomorrow ;) AC, its a secret ;)
Post 91253 by S70T5 on 2006-03-21 18:42:46
Thanks mate :)
Post 91274 by neevo on 2006-03-21 19:12:42
[QUOTE=S70T5]Does anyone have any experience of using the OBD2 - USB interface's you can buy? I would like to get one to remove the SRS error code and turn off my SRS light off. :) Chris[/QUOTE] Just got myself one and have borrowed a lappie from a workmate and will also try using it with my Palm Treo 600. I've got OBD-diag software and another for the palm. That aside, you aren't too far away if you want to try it, hopefully I'll have figured it all out by the weekend (esp. if Justin lets us know what software he's using and I can download it). pm me and we can meetup though if you come here you'll have to wear rose tinted specs as I dont clean! Other than that once I've finished playing I should be able to lend it to you for a week or so using the post. (The dongle, not my workmates' lappie!)
Post 91311 by S70T5 on 2006-03-21 20:03:14
PM sent mate :)
Post 91367 by Unknown on 2006-03-21 21:40:26
[QUOTE=Justin]AC, its a secret ;)[/QUOTE] You and your secrets J.... tsk :troutslap
