Post 92150 by pzorb on 2006-03-24 15:40:11
I need to remove the window regulator cassette - I've got so far as removing the clips on the green bearings that attach to the window rail, but I don't see how the arm bit is meant to come away from the green bearing. Any help?
Cheers!!!
Post 92151 by madness on 2006-03-24 15:42:03
metal clip like a hirclip usually.
Post 92153 by pzorb on 2006-03-24 15:47:07
Hum, is it a case of pulling it away from the rail, leaving the window glass still on the rail?
Post 92235 by pzorb on 2006-03-24 18:35:01
To answer my own question, the lifter arm can be seperated from the lifter rail sliders by using a small 'L' alan key as a crowbar to pry the gap between the lifter arm and the metal attached just underneath the glass. Hope this helps someone some day!
