Grey/white smoke – if it’s the turbo
Post 92767 by iGGy on 2006-03-26 18:54:00
I’d let the car (1996 855R – 120K) idle whilst I packed up my tools after fitting rear mud flaps, I noticed the smoke/vapour coming from the exhaust. A few weeks ago I wouldn’t have given it a second thought; it’s cold and just the usual exhaust condensation. But not with the temperature yesterday and today. If the engine is revved, then there is a stream of the smoke produced and if the rev’s are held, it does appear to reduce in quantity. The smoke isn’t black and it’s not really blue, compared with other oil burners I’ve seen. I’d say it was grey/white and doesn’t particularly smell heavily of oil or petrol. I’m not losing any water and the coolant doesn’t appear to have any oil film. During the week I’ll check the spark plug condition (the engine isn't misfiring) and see as best I can if there’s any oil on the pistons that’d indicate valve stem seals. Compression check will be done. I’ll take the hoses off the turbo and check for spindle play, although I’m not entirely sure how much is too much and see if there’s any oil puddle in the housing. If it is the turbo, is there any benefit of changing from a 15G (looks to be straight flange) to a different model? I’m not planning on an ECU upgrade just yet, but I hope that will come in time. At least I’m sort finding it amusing that just as I think I’ve straightened out all of the faults and done the changes I want to the car…it throws something else at me :slap:
Post 92780 by Unknown on 2006-03-26 19:30:24
Does this go away after a while - especially if driving etc? Could just be condensation in the exahust system.
Post 92788 by Tomcat on 2006-03-26 20:04:58
I have a similar problem with mine and I've recently changed the turbo. Its made no difference at all...
Post 92827 by iGGy on 2006-03-26 22:15:25
[QUOTE=Andrew]Does this go away after a while - especially if driving etc? Could just be condensation in the exahust system.[/QUOTE] I have to admit that I've only noticed it this weekend whilst it was idling. When you're in the car you can't see any smoke etc due to the rear window tint. I did notice what I'd say was a small damp area under the exhaust tip, how much condensation do these cars produce? I had the Impreza idling next to it and that wasn't really producing much vapour. Okay, that's a slightly more modern car and probably does different things with its emissions circuit, so not exactly a good thing to judge by. Only other thing out of the ordinary, if you can really call it such, was that I had to put Esso 95 in on Friday instead of Shell.
Post 92833 by rickbee on 2006-03-26 22:36:34
Mine produces vapour like this. I have always regarded it as steam. Water drips, onto the floor from the tailpipe. Had a BMW 535i which used to do this a lot, the car was white and the vapour would discolor the valance inder the rear bumper. I was surprised one day when I had the rear silencer replaced. When the old one was removed and lying on the floor, about two pints of water came out on to the floor. Condensation! If you do lots of short journeys, the car doesnt get hot enough to evaporate the water. Other cars I have had havnt done this, but have had several other BMW/Audi's which all did.
Post 92880 by mike 850 on 2006-03-27 08:41:27
mine does this too, id say dont worry about it unless you are loosing water, just keep an eye on your levels and it will be fine
Post 92885 by siamblue on 2006-03-27 09:29:15
My standard suitcase exhaust produced tons of steam when idling, when i fitted the TME probably less than half the amount was seen, Gary
Post 92932 by iGGy on 2006-03-27 12:29:10
Thanks for the input. I'll do the checks as a matter of course, but I'm feeling slightly less concerned about it.
Post 92937 by Babybadger on 2006-03-27 12:57:13
Don't forget if you have a flat panel filter as well, you are sucking in a lot of air with a lot of moisture on damp days etc. This will not help with the volume of steam coming from the exhaust.
