Post 94993 by Broaders on 2006-04-03 11:49:55
When adjusting the above is it a case of loosening the nut and turning the bar clockwise or anticlock wise, if that makes sense. ??
First off - If you have to ask this question then I would leave well alone!! The answer is clockwise - and it isnt the bar that rotates - its the nut on the end (the one that is secured in place by the spring clip) You'll need to undo the locking nut first. Remove the spring clip - Pull the bar up so it slides of the top of the wastegate flange rod - and then rotate the end nut. If you dont have the right equipment to set up the pressure in the actuator - I would not rotate the end nut any more than 1 full turn (360 degrees) If you get this wrong and get over zealous - you will spike your engine.
I am trying to cross off the various things that effect my boost spool up time. I am finding with the Rica 280 that I have a second delay after I have kickedown before the boost comes in. Am I right in thinking maybe one turn on the rod may make it spool up slightly quicker ?
I would speak to VT first. Do you believe that your actuator is weak?
[QUOTE=Wobbly Dave]I would speak to VT first. Do you believe that your actuator is weak?[/QUOTE] Rang Adam at VT regarding my problem. I have my car in tommorow at a local volvo specialist for the codes reading and to check all related hoses. Hopefully this may show up some fault as to why it is hesitating when kickingdown.
[QUOTE=Broaders]Rang Adam at VT regarding my problem. I have my car in tommorow at a local volvo specialist for the codes reading and to check all related hoses. Hopefully this may show up some fault as to why it is hesitating when kickingdown.[/QUOTE] Check your other vac/airhoses first. My PCV breather hose to the induction pipe had come out and gave the same symptoms.
