Oil - The basics
Post 95762 by oilman on 2006-04-05 11:52:13
A short lesson on Multigrades: If you see an expression such as 10W-40, the oil is a multigrade. This simply means that the oil falls into 2 viscosity grades, in this case 10W & 40. This is made possible by the inclusion of a polymer, a component which slows down the rate of thinning as the oil warms up and slows down the rate of thickening as the oil cools down. It was first developed some 50 years ago to avoid the routine of using a thinner oil in winter and a thicker oil in summer. For a 10w-40 to attain the specification target a 10W ( W = winter) the oil must have a certain maximum viscosity at low temperature. The actual viscosity and the temperature vary with the viscosity grade but in all cases the lower the number, the thinner the oil, e.g. a 5W oil is thinner than a 10W oil at temperatures encountered in UK winter conditions. This is important because a thinner oil will circulate faster on cold start, affording better engine protection. For a 10w-40 to attain the other specification target a 40 oil must fall within certain limits at 100 degC. In this case the temperature target does not vary with the viscosity grade, if there is no "W", the measuring temperature is always 100degC. Again the lower the number the thinner the oil, a 30 oil is thinner than a 40 oil at 100 degC., which is typical of maximum bulk oil temperatures in an operating engine. The engine makers are, of course, very well aware of this and specify oils according to engine design features, oil pump capacities, manufacturing tolerances, ambient temperature conditions etc. It is important to follow these guidelines, they are important and are an are stipulated for good reasons. If the engine has been modified, the operating conditions may well be outside the original design envelope. The stress on the oil caused by increased maximum revs, power output and temperature may indicate that oil of a different type and viscosity grade would be beneficial. Cheers Simon
Post 95774 by pzorb on 2006-04-05 12:32:07
http://www.google.com/search?q=oilman+multigrade+modified+viscosity Fiat, Vauxhall, GT-R, Skoda, MG Rover, MR2, Subaru, Punto, 300zx, Corsa, Lancer, Ford XR, Seat Cupra, VW Corrado, Renault Alpine, Pug 106, MX-5, Ford Fiesta, etc! & now Volvo. You're quite an expert.
Post 95785 by Vikingxl on 2006-04-05 13:48:49
Seems he has nothing else to do Pzorb although we dont seem far behind him lol
Post 95791 by pyrotechnictigger on 2006-04-05 14:25:10
Oilman, want to buy some fireworks? I have a shop you know:)
Post 95806 by jimmyc on 2006-04-05 16:04:02
wow he is even called oilman thanx fookin scary :troutslap
Post 98992 by neevo on 2006-04-14 19:19:34
Thanks for the info Simon. Wasn't too clear on the real meaning of those numbers despite having it explained to me before! Makes more sense now :)
Post 99094 by Jod T5 on 2006-04-15 10:18:37
You do all realise this guy sells oil on every forum on the net dont you and not everyone is a happy bunny.....
